Silverstone 140mm fan filter
Solved by W-L,
Problem is my lower fan has hard drive cages on the other side D:
Guess fan grills are my only solution now....
How exactly?
Just use some rigid plastic such as strips like zip ties to make some bars and attach them to the filter so they don't let the center of that mesh from hitting the fan blades, if you want the easiest solution either some fan grill or new rigid filters will be the quickest solution.
Featured Topics
2
1
ave11 ·
Posted in Troubleshooting2 -
2
2
2
IamBis ·
Posted in General Discussion2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
