What will skylake be?
Go to solution Solved by Prastupok,
NO if they made an unhyperthreaded 6 core would it be better at heavt gaming and recording with light streaming than a hyperthreaded 4 core
Doubtful. Any they won't make a 6 core on the mainstream platforms... I'd bet money on it.
If there is a hyper threaded 4 core like 4790k then would it be better than unhyperthreaded 6 core from Intel at heavy gaming and recording and light streaming. Does anyone think that Intel will make an unhyperthreaded 6 core just trying to find out how powerful hyperthreading is and whether or not most programs and games know how to use it?
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/346180-what-will-skylake-be/
Slow yourself, young padawan... Broadwell first. Then we'll talk skylake.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/346180-what-will-skylake-be/#findComment-4714340
Some are already speculating Cannonlake.
I know. And it needs to stop. Just like the 390x. It's not out, so theres no point in talking specs and pretending we know what's going on with them.
https://linustechtips.com/topic/346180-what-will-skylake-be/#findComment-4714356
Ok then asking about now which would be better a hyperthreaded four core or an unhyperthreaded six core?
That depends on what you're doing...
https://linustechtips.com/topic/346180-what-will-skylake-be/#findComment-4714387
They make unhyperthreaded 6 cores? When?
And if you talkin bout AMD, a hyperthreaded 4 core is better then any FX 6xxx or other variants
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/346180-what-will-skylake-be/#findComment-4714435
https://linustechtips.com/topic/346180-what-will-skylake-be/#findComment-4714502
https://linustechtips.com/topic/346180-what-will-skylake-be/#findComment-4714515
k just wondering since setup for 5820k is way more expensive than 4790k!
Enthusiast parts cost enthusiast prices.
https://linustechtips.com/topic/346180-what-will-skylake-be/#findComment-4714532
