Get Headphone Amplifiers/DAC or a sound card?
Solved by SSL,
Simplifying greatly, a soundcard is just a DAC chip on a PC add-on card. It does the same thing as an external DAC, except it goes inside your PC. As such soundcards are NOT recommended because the are vulnerable to EMI and possibly power fluctuations. Only get one if you need the software features or need to drive a surround speaker system.
If you can play music as loud as you want and are not hearing static, humming, buzzing, clicks, or pops coming from your headphones or speakers, then you probably don't need to go buy anything either way.
