Bang for Buck Case
You didn't tell us the motherboard standard or anything, so I'm gonna presume ATX.
I do like me a 300R
Case: Corsair 300R ATX Mid Tower Case  (£58.79 @ Aria PC)
Total: £58.79
Generated by PCPartPicker 2015-04-09 18:23 BST+0100
Best bang for buck is an S340, but I think you can only get those from Scan
https://linustechtips.com/topic/344675-bang-for-buck-case/#findComment-4695013
http://uk.pcpartpicker.com/part/nzxt-case-cas340wb1
http://uk.pcpartpicker.com/part/corsair-case-300rwindowed
Damnit, partpicker seems to have just gone down for me
Also the BitFenix Ronin
I do like me a 300R
PCPartPicker part list / Price breakdown by merchant
Total: £58.79
You can get S340 from Overclockers UK as well :D
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/344675-bang-for-buck-case/#findComment-4695027
The cooler master N600 is pretty good bang for the buck.
GPU: Gigabyte GTX 970 G1 Gaming CPU: i5-4570 RAM: 2x4gb Crucial Ballistix Sport 1600Mhz Motherboard: ASRock Z87 Extreme3 PSU: EVGA GS 650 CPU cooler: Be quiet! Shadow Rock 2 Case: Define R5 Storage: Crucial MX100 512GB
https://linustechtips.com/topic/344675-bang-for-buck-case/#findComment-4695030
My case :P
Corsair Spec 03
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/344675-bang-for-buck-case/#findComment-4695076
https://linustechtips.com/topic/344675-bang-for-buck-case/#findComment-4695262
