fans helppppp
Go to solution Solved by I'm Batman,
can i use engine oil and i know its a bit weird why do i have engine oil.........
yes you can use it its really similar to WD-40
help my fans are making more sound than normal plus it slowed down and after i shutdown my computer i opened my case and gave the fan a spin with my finger it seemed it was doing the same sound and then i started my computer again it decreased,what can i do to solve this
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/34463-fans-helppppp/
hope someone helps me
ExSystems
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-441490
not sure what type of bearing you fans have,but try cleaning the dust from the hub first and spray some WD-40 to it..its a bit ghetto fix i know..if nothing is fixed,i think you do need to get new fans
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-441662
ExSystems
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-441779
Umm I wouldn't know if that would work.
ummmm thanks anyway
ExSystems
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-442124
well thanks everyone if this problem gets worse than i know what to do thanks all :3
ExSystems
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-442468
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-443206
Most likely replace your fans. Dust and grim is the most likely cause to the noise.
ouu man you are everywhere o.O
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-443212
Get new fans or try to clean it at least
MB :MSI Z77a G45 | Proc: I5 3570K (Stock) | HSF : CM 212X turbo | RAM : Corsair Vengeance 8GB (2X4GB) | VGA : MSI GTX 660 Twin Frozr | PSU : Corsair GS600 | Case : CM Storm Enforcer | Storage :  OCZ Vector 128GB, WD Blue 500GB , Samsung 840 Evo 120GB, WD Blue 1TB
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-443239
No it's not! Engine oil and WD-40 is not similar at all. Engine oil is designed to lube metal moving parts that cause friction. WD-40 is a liquid spray not designed for moving parts under friction it's to loosen rusted bolts stop minor sqeeks on parts while you could possibly use it on a PC fan for a short fix the WD-40 will loose it viscosity very quickly because it's not designed for that type of use.He's better off using small amount engine oil or better yet just buy a new fan.
Motherboard: MSI-990FXA-GD65 | CPU: AMD FX-8350 @ 4.3Ghz | CPU Cooler: Corsair H100 | RAM: 8GB Corsair Vengeance 1600Mhz | GPU: MSI GTX 770 Lightning @ 1300Mhz CC and 8000Mhz MC | Case: Fractal Design ARC Midi R2 | PSU: Corsair AX850 | OS: Windows 8.1
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-443382
just buy new and better fans instead
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-454762
thanks all
ExSystems
https://linustechtips.com/topic/34463-fans-helppppp/#findComment-455117
