Okay, I'm trying to derive the equation for centripetal acceleration. Thus far I have this for the x component: acceleration= second differential of position vector.
I'm just confused to how I differentiate -r.dθ/dt.(Sin(θ)) any help would be appreciated.
https://linustechtips.com/topic/342618-need-help-with-physicsmaths/
My brain just hit the fan.This looks like some witchcraft.
You don't wanna see how trig looks like then.
Or anything more "sophisticated" .
with respect to t?
yeah
yeah
What's dθ?
What's dθ?
well I differentiated with respect to t using the chain rule for dr/dt(cosθ) dθ is the small change in angle I think.
im glad my math homework looks like this: 3x(x-2)=2 what is x, please answer btw im very confused
x = 3+sqrt(15)/3 or x = 3-sqrt(15)/3
newtons differentiation notation is usually more convenient in these situations.
(trying to make the best of an accidental dp)
I've never come across that notation, seems a lot cleaner... Thanks :D
You could use the liebniz rule, or just think of it as the product rule with one of two product being a double product itself.
  https://i.imgur.com/SgB60cg.png
So in general terms it would be like this?
someone needs to write a program where i just hold my webcam up to my math book and it sees the text, understands the exercise and draws the answers with a pencil with a robot arm into my notebook. my gpu has a couple of teraflops, should be enough
this? https://photomath.net/en/
Can't do matrices
seriously, matrices are the most annoying thing to try to type out on your phone into octave/wolframalpha, etc.
Depending on what you're doing with a matrix there's cyanogen mod calculator that's pretty good for matrices:
https://play.google.com/store/apps/details?id=com.android2.calculator3&hl=en_GB
