Hiya, I am planning my first build and was aiming to get an acceptable frame rate on high setting on GTA V, could you have a look over to point out any problems or improvements
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  (£155.26 @ Ebuyer)
Motherboard: Gigabyte GA-H97-D3H ATX LGA1150 Motherboard  (£84.16 @ More Computers)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  (£184.13 @ Amazon UK)
Case: Zalman Z3 Plus ATX Mid Tower Case  (£26.99 @ Amazon UK)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  (£13.00 @ Amazon UK)
Monitor: LG 22MP55HQ-P 60Hz 22.0" Monitor  (£103.13 @ Amazon UK)
Other: Windows 8.1 (£14.00)
Total: £768.55
https://linustechtips.com/topic/342583-planning-my-first-pc/
A tad bit more expensive but much better.
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (£143.99 @ Ebuyer)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  (£33.72 @ CCL Computers)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  (£273.18 @ Aria PC)
Case: NZXT Source 210 (White) ATX Mid Tower Case  (£30.25 @ Scan.co.uk)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (£33.59 @ Aria PC)
Total: £779.75
Generated by PCPartPicker 2015-04-06 15:43 BST+0100
https://linustechtips.com/topic/342583-planning-my-first-pc/#findComment-4667244
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  (£155.26 @ Ebuyer) ..change to a 4460
Memory: Kingston Fury Black Series 8GB (1 x 8GB) DDR3-1600 Memory  (£49.12 @ Amazon UK)..change to a 2x4gb kit
Storage: Sandisk Solid State Drive 128GB 2.5" Solid State Drive  (£43.98 @ Dabs) ...change to a 850 evo 120 or 250 if you can afford it
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£41.79 @ Amazon UK)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  (£184.13 @ Amazon UK) ..try to bump this up to a 290
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£52.99 @ Amazon UK) ..change to a seasonic or xfx 600w
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  (£13.00 @ Amazon UK) ...don't use wireless if you have a option..use a powerlike adapter kit
Monitor: LG 22MP55HQ-P 60Hz 22.0" Monitor  (£103.13 @ Amazon UK) ...would try to get a 24 inch
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/342583-planning-my-first-pc/#findComment-4667264
PCPartPicker part list: http://uk.pcpartpicker.com/p/hnFvcf
Price breakdown by merchant: http://uk.pcpartpicker.com/p/hnFvcf/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£174.00 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£24.99 @ Amazon UK)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (£62.36 @ Scan.co.uk)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  (£49.99 @ Amazon UK)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  (£54.99 @ Amazon UK)
Video Card: XFX Radeon R9 290 4GB Double Dissipation Video Card  (£225.76 @ Aria PC)
Power Supply: Silverstone Strider Essential 700W 80+ Bronze Certified ATX Power Supply  (£53.64 @ Scan.co.uk)
Monitor: BenQ GL2250HM 60Hz 21.5" Monitor  (£89.99 @ Amazon UK)
Total: £817.50
Generated by PCPartPicker 2015-04-06 15:54 BST+0100
https://linustechtips.com/topic/342583-planning-my-first-pc/#findComment-4667293
Total: £768.55
You plan on using it for anything else? streaming? editing? recording? Or just pure gaming?
7800X3D - MSI B650 MAG Tomahawk - 32GB 6000mhz CL30 - Gigabyte 3080 TI - 2TB NVME - 1000w PSU - ID Cooling 240mm AIO
https://linustechtips.com/topic/342583-planning-my-first-pc/#findComment-4667310
Just over £800 but i think it would be worth it
PCPartPicker part list: http://uk.pcpartpicker.com/p/cCkppg
Price breakdown by merchant: http://uk.pcpartpicker.com/p/cCkppg/by_merchant/
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  (£49.36 @ CCL Computers)
Storage: Sandisk Solid State Drive 128GB 2.5" Solid State Drive  (£42.98 @ Novatech)
Case: Cooler Master N200 MicroATX Mid Tower Case  (£32.86 @ CCL Computers)
Power Supply: be quiet! 500W 80+ Bronze Certified ATX Power Supply  (£46.20 @ Scan.co.uk)
Total: £808.75
Generated by PCPartPicker 2015-04-06 15:55 BST+0100
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
https://linustechtips.com/topic/342583-planning-my-first-pc/#findComment-4667315
I wasn't planning on anything like that but it might be something to consider. The only other things that I was going to be doing with it was university work, some 3D modeling and light use of things like MATlab
https://linustechtips.com/topic/342583-planning-my-first-pc/#findComment-4667346
This guy (below) knows what he's doing. You should follow his buil:
Total: £779.75
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/342583-planning-my-first-pc/#findComment-4667501
