Blue Yeti Thumping noise
By
azurite2
in Peripherals
in Peripherals
Solved by azurite2,
I guess you can say it's not a hardware problem.
Maybe it has to do with what Skype and DxTory do with the audio after it is received or something..
Ok I have discovered that turning the on mic gain to almost zero and boosting the computer gain gets rid of the noise!
edit: it came back
Featured Topics
Scorpiopt ·
Posted in Troubleshooting0 -
1
ThankGodItsFriday ·
Posted in Programs, Apps and Websites1 -
frostymelts ·
1
RevGAM ·
Posted in Custom Loop and Exotic Cooling4 -
JakubR88 ·
Posted in Power Supplies6 -
2
2
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
