hyper 212 evo 2 fans
Go to solution Solved by Levent,
you will only get 5-6 Celsius improvement over single fan in best scenario ,i tried with 2 3k rpm fans and second fan made no improvement at all but adding second fan (slower one) to stock fan of evo made 2 degree improvement under load and increased the noise 2 times over single fan
is it worth getting a 2nd fan for the 212 i know it comes with the mounts for it but is it fully worth.
i will be getting the cooler in a few days and would be wondering for future upgrading would it be worth it.
another random question how far can i push the fx 6300 with this cooler.
main rig: http://uk.pcpartpicker.com/p/GFvH7P
next upgrades. h440 . 8320.  possible liquid cooling AIO
https://linustechtips.com/topic/34151-hyper-212-evo-2-fans/
https://linustechtips.com/topic/34151-hyper-212-evo-2-fans/#findComment-437679
What motherboard do you have? I have the ASUS m5a99x evo R 2.0 and i can only get 4.2 so far (I have this cooler:http://www.amazon.com/Rocketfish-RF-UPCUWR-Universal-CPU-Cooler/dp/B0030U9ET0) and i get good temps at 4.2.
You could probably get away with 4.3-4.5 depending on your motherboard
https://linustechtips.com/topic/34151-hyper-212-evo-2-fans/#findComment-437781
i recommend buying a second fan... as long as you remove the stock one...
rly push pull only increase noise and doesn t improve temps enough to be worthwhile.
replacing the stock fan tho is a good idsa if you find it noisy atm as many aftermarket fans can get close to the same performance with less noise.
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/34151-hyper-212-evo-2-fans/#findComment-439546
  • 2 weeks later...
Has anyone put a fractal 120mm fan on a 212?  I'm looking to do this as my current arctic cooling fan is wimpy.
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
https://linustechtips.com/topic/34151-hyper-212-evo-2-fans/#findComment-485997
Basically, if the fan is strong enough to push the air through the heatsink, adding a second fan will give little to no improvement.
https://linustechtips.com/topic/34151-hyper-212-evo-2-fans/#findComment-487715
