Corrosion Help?
The thing I really wanna know is whether to go full copper in a loop?
This is saying there's no real practical matter of doing so, since even with full copper, the fluid should be changed periodically due to fluid turning conductive(potential frying components if leaked).
Nickel and copper should work pretty well.
EK had bad(thin and unsolid??) nickel plating which for some reason happened to be oxidized(corroded), then affecting the block.
So what's the real cost of this if it's not galvanic? Their problem seems to be resolved already...
If you have the budget to go full copper i would. copper will disapate heat better than nickle. and much better than aluminium
if the inside has thin galvanization or is inproperly galvinized it won't make any difference, they might as well not galvinize it at all. the bare portions of the aluminum will react and corrode underneath the nickle plate causing large porous flakes to get caught in your loop.
Okok so to conclude if I have a Ek copper water block, with a gpu water block that is Copper and the inside of my MB (Maximus Formula VI) is aluminum (anodized). Would that all work with a copper radiator and mayhams White with anticorrosion?
Thanks
yes. it will work.
again, just use premix and it will last longer and be safer.
