Corsair H100i Questions
Solved by TheMidnightNarwhal,
Can I buy seperate SP fans to put on it instead of the stock ones with the cooler? Do they have to be 120 or would 140 mm fit?
Any 120mm fan will fit. Just make sure you get static pressure fans.
Featured Topics
Scorpiopt ·
Posted in Troubleshooting0 -
4
ThankGodItsFriday ·
Posted in Programs, Apps and Websites2 -
frostymelts ·
Posted in Troubleshooting4 -
3
RevGAM ·
Posted in Custom Loop and Exotic Cooling8 -
JakubR88 ·
Posted in Power Supplies8 -
2
3
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
