I am almost finished picking the parts for my new build. This is my part list:
PCPartPicker part list: http://pcpartpicker.com/p/VrdgHx
Price breakdown by merchant: http://pcpartpicker.com/p/VrdgHx/by_merchant/
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  (Purchased For $120.00)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard  (Purchased For $90.00)
Memory: Corsair XMS3 4GB (1 x 4GB) DDR3-1600 Memory  (Purchased For $40.00)
Memory: Corsair XMS3 4GB (1 x 4GB) DDR3-1600 Memory  ($39.99 @ Amazon)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($89.89 @ NCIX US)
Storage: Western Digital Caviar Green 2TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: EVGA GeForce GTX 960 2GB Superclocked Video Card  ($194.99 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($44.99 @ NCIX US)
Total: $619.86
Generated by PCPartPicker 2015-03-28 21:59 EDT-0400
As you can see, I already have the i3, the motherboard, 4GB of RAM and a 2TB HDD. I need help picking up a case. I would prefer a $50 case, but I can stretch my budget to $70.
I know I could maybe get better hardware with my budget ($800 or so) but I live in Costa Rica and I need to add at least $150 of shipping and import tax. BTW I am open to suggestions if you think I could swap some parts in this list. Thanks.
https://linustechtips.com/topic/337299-best-pc-case-50-70/
I am voting for the NZXT Source 210 Elite. It is a great budget case! Otherwise, for a bit more, I would suggest the Cooler Master HAF 912. I have worked in both and both are great cases!
edit
ahaha, wow, ninja'd by Tim. :)
https://linustechtips.com/topic/337299-best-pc-case-50-70/#findComment-4601216
edit
With 2/3 choices already made by me ;)  :ph34r:
https://linustechtips.com/topic/337299-best-pc-case-50-70/#findComment-4601225
Zalman Z3 Plus you get viewing window plus it comes with 4 fans.
Magical Pineapples
https://linustechtips.com/topic/337299-best-pc-case-50-70/#findComment-4601239
My build is similar, I have this case and I would strongly recommend it!
http://www.superbiiz.com/detail.php?name=CA-COM100K&c=CJ (55.99)
Theres also a windowed version(which is what I have) here:
http://www.superbiiz.com/detail.php?name=CA-COM10KW (46.99, not sure why this one is cheaper lol)
I have no idea what I'm doing
https://linustechtips.com/topic/337299-best-pc-case-50-70/#findComment-4601286
CM N200.
https://linustechtips.com/topic/337299-best-pc-case-50-70/#findComment-4605995
