Fan Controller?
Solved by Bleedman0xx,
Any specific products from them you recommend? I just want to hook up my one 200m intake, 3 exhaust, and possibly a watercooling pump...
The CW611 and FC5 V3 were made with water-cooling in mind. You can hook up things like fans and flow-meters to the controller and monitor them.
I recently bought the CW611, bit pricey but the build quality is good. Haven't had the time to use it in a build just yet but I've read good reviews.
