Hello. I recently just made a thread about an Irremovable Mobo Screw
Is it possible to restore a such badly took care of case to the point of washing it. The case is really good though i cannot replace the front panels, i can remove the old stickers.
I have removed the Standoff that was irremovable with pliers so.. .technically clean, appearance? It is filled with cobwebs and dust i have a can of spray paint, matte black. The rear I/O Panel has been removed. Questions:
  1. I wanna wash it, will that short the circuit out, the circuit of the front I/O plugs?
  2. Advice before i spray paint it?
  3. Oh this is not about cases but ill put it in here: How to wash dried out Thermal Paste, THICK dried out thermal paste without scratching the metal surface on the CPU.
  4. If the case turns out good ill post it here
Few notes:
  • The case CAN BE DISASSEMBLED FULLY, I can remove the top, bottom, sides, and front panels of the case to the point where it is just BONES.
  • No brands on this case
  • The location of the PSU is old school: Top.
Thats all. Hope you guys can help me, i really want to use this case for my next build!
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/336155-case-restoration/
1..go ahead and wash it..just make sure its totally dry before using..I use a air compressor to dry parts
2...sand it and use a good primier
3. carburator cleaner
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/336155-case-restoration/#findComment-4587204
  1. I have a big fan like for events, called the HURRICANE, On mode 4 its like a leafblower...
  2. I have no experience in spray panting or whatsoever but this will be a hell of a damn experience +500XP
Thx mate
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/336155-case-restoration/#findComment-4587235
Few notes:
1) remove everything. wash it out. leave it in the sun to dry for about 2 days. make sure it is 100% dry.
2)as above, sand it down to the metal, use aluminum primer and then spray paint it. (i like 500degree engine enamel, but that's just me. )
3)a toothbrush and rubbing alch. lots of it.
deconstruct the case as much as possible before washing.
IMO old school top mount PSU works better sometimes. less chord travel to the 24pin.
OP, seriously sand as much as you can at all angles. this should take an hour or two. but once it's shiney, prime it, give it 5-10 minutes to sink in, then spray it.
prime and spray it on grass, or over lots of cardboard. do NOT let any outside particles get on the paint.
spray it in stoking bursts. moving quick ly from side to side almost as fast as you can with short bursts of paint released during each pass, this gives a more even professional coating.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/336155-case-restoration/#findComment-4587252
Awesome do it!
I would have done the same,if my case wasn't missing so many features
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/336155-case-restoration/#findComment-4587463
Sand, go it. What about newspaper?
Awesome do it!
Should i make a thread about it or just edit the one here?
EDIT: I washed it like half an hour ago. Whole without the side panels and such. This is gonna be an epic LOG
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/336155-case-restoration/#findComment-4587580
updates here. or create a whole build log thread.
newspaper or cardboard are both fine to spray on.
just watch out for overspray. it's when things near the background of the spray get covered in tiny tiny spray dots.
https://linustechtips.com/topic/336155-case-restoration/#findComment-4587603
