There is a problem with my PC that occurs at random times where my PC case powers up but nothing else in the system seems to power on (though there is a light on the ethernet port on the motherboard). Recently, I have been experiencing crashes and various other issues with my graphics card, you can find these posts in my profile.
My specs are as follows:
ASRock H97M-Pro4
Intel Core i5 4590
Gigabyte GTX 970 G1 Gaming
Kingston HyperX Fury 8GB DDR3 (2xDIMMs) 1600mhz
Corsair CX-750M
Any help would be appreciated.
Regards,
Tofite.
https://linustechtips.com/topic/335485-pc-startup-problem/
ASRock H97M-Pro4
Intel Core i5 4590
Corsair CX-750M
Regards,
Tofite.
Sounds like PSU issue to me.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/335485-pc-startup-problem/#findComment-4576767
swap the PSU out and see if that fixes it, otherwise the MB might be deadish.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/335485-pc-startup-problem/#findComment-4576772
remove the GPU
clear the CMOS and set the boot priority
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/335485-pc-startup-problem/#findComment-4576780
does this happen when you first build this PC?
https://linustechtips.com/topic/335485-pc-startup-problem/#findComment-4576865
No, these various problems started about 1 month after I built the PC.
what was the last thing you did to your PC and this happen?
https://linustechtips.com/topic/335485-pc-startup-problem/#findComment-4576874
I did nothing to the PC, it just happened out of the blue.
ok what i suggest is run without the GPU
see if the blank screen happens with the PC running only the onboard output
and report back the results
https://linustechtips.com/topic/335485-pc-startup-problem/#findComment-4576898
Is your GPU is overheating ?
If that is the case, you could download OpenhardwareMonitor.
You can run a plot on GPU temperature (select GPU temp) then view as a plot, and set time window to 10 or 20 minutes.
Then play your game, and once in a while pause to check your temperature. You should be able to see the temperature behaviour of the GPU as you are playing. and pausing.
Good luck!
http://openhardwaremonitor.org/downloads/
https://linustechtips.com/topic/335485-pc-startup-problem/#findComment-4582736
Good luck!
My GPU doesn't overheat, it rarely goes above 65 C.
https://linustechtips.com/topic/335485-pc-startup-problem/#findComment-4599373
Bump
did you follow my suggestion?
remove the GPU and let the system run
https://linustechtips.com/topic/335485-pc-startup-problem/#findComment-4608492
Do you have by any chance a extra PSU you could try out as it sounds like your PSU is crapping out on you so it is not supplying enough power to all your components especially the GPU...another thing you can try to do is if you also have a extra GPU,you do need one like you have now just try any GPU should let you know if there is a problem with your main GPU..
I would try to narrow it down to one part at a time such as a GPU first as it be the easiest to change first,then if that does not work try a PSU.
It also sounds like something is getting very hot and this would also cause your PC to crash,did you notice if all the fans on your GPU,CPU and PSU are spinning...I would also check to make sure nothing has came loose such as all your PSU wires going to each component.
Now this is just a suggestion but you could remove your CPU heat sink and reapply new thermal compound as it would not hurt just to make sure it is getting a good heat transfer between your CPU and your heat sink..
https://linustechtips.com/topic/335485-pc-startup-problem/#findComment-4608668
