i want to upgrade my CPU and MOBO
from this spec:
ASUS P7P55D
Intel® Core i5 CPU 760 @ 3.4GHz‏
Antec H2O 920
RAM: G.Skill 2X4 GB F3 @ 1333
MSI Radeon R9 270X OC
Corsair VX550W
KingStone 120GB
2TB HITACHI
Dell E2213H
to
Intel Core i7 4790K
Gigabyte GA-Z97X
friend of mine said that i wont see much difference  in gaming
i play mostly ARMA 3 and BF 4 (which is correctly deleted for the favor of arma 3 in the ssd) and the planning to play GTA V i am very picky in my games
Case: NZXT H440 CPU: i7 6700K @ 4.0 Cooler: Antec Kuhler H2O 920 Graphics Card: Zotac Mini GTX1070 Ti Motherboard: Gigabyte Z170 K3 RAM: Kingstone Fury 2x8GB Storage: Crucial P1 SSD, Seagate - Barracuda 2TB 3.5, Hitachi - Deskstar 500 3.5" PSU: Corsair Enthusiast 550W 80+ Mouse: Logitech G403 OS: Windows 10 Home 64bit  Audio: ATH-AD500X
https://linustechtips.com/topic/334860-i-will-see-difference/
SNIP
spend that money on a better GPU instead :)
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565688
If you're just looking for gaming performance a 4690k will be enough.
Main PC: 4690k, LMG Edition G1 Gaming GTX 980, 16GB Hyper X Fury, Asus Z97-A, EVGA G2 850W, Crucial MX100 128GB, WD Red 1TB 2.5", Dark Rock 3
Laptop: Asus UX305 Monitor: Asus PB278Q Keyboard: Filco Majestouch 2 TKL Mouse: Corsair M65
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565694
Mmm, yeah in BF4 and Arma you should see a difference in upgrading the CPU.
Both those games like threads/cpu's in general.
Do you only do gaming though? If so, go for a i5 4690K.
And upgrade your GPU. (because getting an i5 will save you some)
@Sharon24 don't forget to follow your topics and quote people when answering them
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565699
ohh and i forget to mention i video editing ( not much)
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565710
I would wait to upgrade the gpu though. See what AMD brings out with their 300 series.
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565717
Depends on where you live.
If you're in a region where they use the €, it's probably not that smart to wait  even longer.
GPU's are getting more expensive here.
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565729
I'm not sure if a 4790K is worth it over the 4690K if you only do a bit of video editing
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565734
Good point. In that case sooner may be better.
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565741
¯\_(ツ)_/¯
That is one of the reasons why location is often so important for a build or advice.
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565752
I'd say probably not.
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565753
¯\_(ツ)_/¯
Pricing and availability isn't that important for buying things. Oh, wait...
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565772
in israel the prices are NEW ISRAELI SHEKEL but becuse is imported is priced at $ which mean each USD is 4 Israeli shekel (for now)
https://linustechtips.com/topic/334860-i-will-see-difference/#findComment-4565784
