So im just wondering what the "max volume" (1-100 in windows) it's safe to use without
damaging my headphones (ath-m50), i use 25 which isn't a problem but sometimes i turn
it up to 100 and just use my headphones on the desk as speakers lol.
Any ideas on where the line goes beetween ok and too much?
https://linustechtips.com/topic/332224-max-volume/
depends on your soundcard/amp, if you use onboard audio I wouldn't worry too much.
CPU I7 - 4720HQ RAM 2 x 8GB • GPU Nvidia GTX 850M Storage 250GB 850 EVO - 1TB Seagate Hybrid
Keyboard CM Storm QuickFire Rapid-I (MX brown) & Pok3r (MX clear) • Mouse Logitech G502 • Sound Audio-Technica ATH-M50X • OS Windows 10 Pro - Linux Arch
Storage Asustor AS7004T
https://linustechtips.com/topic/332224-max-volume/#findComment-4509405
By the time you would damage your headphones you´ve already damaged your hearing.
TL;DR much? ;)
I am not sure, but I don't think using your closed back headphones as speakers is good.
https://linustechtips.com/topic/332224-max-volume/#findComment-4509426
TL;DR much? ;)
I sometimes do this too, it doesn't sound good but sometimes all you need is some background noise.
https://linustechtips.com/topic/332224-max-volume/#findComment-4509476
I do it too sometimes, but my headphones are open back and generally have shitty sound leaking.
https://linustechtips.com/topic/332224-max-volume/#findComment-4509507
I just don't have speakers that's why i use them as speakers, just don't want to f**K them up.
Simple. Stop using it with ways it's not meant to be used. Think about it this way: if you're using F1 to do paris-dakkar rally, what's the probability of you wrecking that F1? Simple, because F1s are never meant to do rallies....
https://linustechtips.com/topic/332224-max-volume/#findComment-4510227
