Shocks or What? Car Help
stiff suspension is normal for a 'sport car*" not to mention you came from a comfy lumina
maybe you need an alignment?
*that car doesnt deserve to be called a sport car
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505488
Not a specialist on the matter, brah, but could be a simple wheel misalignment.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505493
The pulling is probably that for sure, I could probably have em check my car out when I get that done.
Caster angle, most likely.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505500
1. Walk around the car a few times and try to push down the suspension on all four corners. (Any noticable difference?)
2. If not. Get the car up so you can rotate the tires. (Any sticking, Grinding, Scraping?)
3. Visually inspect the shocks
4. Have an alignment shop look at it if all else fails.
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505501
Yep. As for the bumpiness, could be the dampers.
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505502
first thing to do is to get an alignment. The toe on each side is probably off which is causing the pulling. If it is suspension related it could be a blown shock. A good way to test this is to press down on each corner of the car and let go. If it comes back up and does not bounce, that means the shock is probably good and has some life left in it, if it bounces at all, that means the shock is blown and is not damping anything.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505516
Yeah, your car just needs an alignment to fix the pulling issue. For me, as long as its not pulling hard its not worth taking it in for an alignment(so right now my Camaro pulls to the right, but its not an issue. Before my alignment when I bought it, it damn near pulled you into the ditch lol). As for the suspension, its pretty typical for a 90's and back to feel rough. You can upgrade the suspension with todays "low end" stuff and it will smooth things out since technology has gotten better over the years.
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505525
Does it pull to the right all the time? Or just when doing something like breaking? Could also be alignment related.
If you want a really smooth ride then sell the car. How rough is the road the it feels bumpy on?
It pulls to the right VERY slightly all the time. It would probably take 1/4 Mile to cross a lane at the pull rate though. The road it feels bumpy on is a bone stock road, just average.
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505527
When you take her in for alignment, make sure they compensate for the road's crown.
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505538
Cars? Is this really a thread about cars?
Even if there was a car expert here...
.....You do realize you're talking to a bunch of geeks & nerds, right?
Maybe a car forum? Or.. Local? Better yet..
Google will answer your question, I promise.. She knows the world.
« Current PC ~ Phantom Beast »
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505552
Not a good idea. Doing that will cause uneven tire wear. replacing tires is much more expensive than getting a proper alignment. Camber, toe, and caster should be mirrored on bot sides of the car.
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505557
Google will answer your question, I promise.. It knows the world.
... *Cough* http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/*Cough*
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505559
You have no clue who is on here do you..
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505560
Clueless
"Rawr XD"
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505565
beat me to it. There are allot more car guys on here than most would think :D
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505567
Sounds like alignment. I would do as @techswede said and check all corners first if you can. But I wouldnt worry after that. My el camino had the wheel at a 20 degree angle for years.
Bumpy could possibly be a tire balance issue. Its bumpy not bouncy right?
Blarg
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505584
You guys are joking right?
Because I couldn't make it more obvious that I was dudes!..
Although I must admit.. I didn't know about that 376 page car thread.. Pretty cool.
And obviously, LTT = Highest IQ Level site on the internet.. Only person who knows more than us is, again.. Google.
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505585
Bump, not bouncy! :)
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505588
As a general rule, they usually do allow more pull off the side. It's how most, if not all shops DO alignments
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505590
Could be alignment or tires. My CR-V is perfectly fine with my summer tires, but with the winters on, it noticeably pulls to the right when I let go of the wheel on non-snowy roads, it also shakes like hell too (lol rip balancing). Maybe I shouldn't have cheaped out on winter tires...
There's even car-savvy girls here xD tmyk
Desktop: Intel Core i5 2380P (2400 w/o iGPU), MSI H61, 8GB RAM, 256GB SP610, 500GB WD Blue, HIS R9 280, Antec TruePower Classic 550W, Inwin MANA 134, QNIX QX2710, CM QuickFire Rapid, Logitech G402
Laptop: Toshiba Satellite L40D, AMD A6-6310, 6GB RAM, 500GB HDD, Radeon R4 Graphics, 14" 1366x768
Phone: iPhone 6 Space Gray 64GB, T-Mobile $60/mo 3GB plan
https://linustechtips.com/topic/331876-shocks-or-what-car-help/#findComment-4505668
