Difference between Windows 8.1 products?
Go to solution Solved by NumLock21,
Retail: license is with the user, can transfer to as many computer as you like as long as it's running only on 1 computer
OEM: tied to the system. Can upgrade that system say motherboard, hdd, and so forth, but cannot transfer license to a brand new computer.
Retail comes in both 32bit and 64bit disc in a single package and your key is on a business like card.  OEM just comes with only the platform you bought, so bought 32bit, then it will only have the 32bit disc. OEM key is on a sticker label.
i5-4690K@4.5 GHz // Asus Z87-Pro // HyperX Fury 8GB DDR3-1600 // Crucial BX100 250GB // Sapphire Nitro R9 390 // EVGA SuperNOVA 750W G2 // Fractal Design Define S // be quiet! Pure Rock & Pure Wings 2 // BenQ XL2730Z // Corsair Vengeance K70 // Logitech G403 Wireless // Sennheiser HD 598 SE
https://linustechtips.com/topic/330746-difference-between-windows-81-products/
nothing note worthy imho. OEM is made for system builders its usually vastly cheaper, for whatever reason it isnt in this case. to my understanding OEM is basicly tied to the system in question where non OEM can be reinstalled on various systems...but I think it invalidates other installs I could be wrong though
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Mate, I think you can mark NumLock's post as answered. Tis pretty much correct. :)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
How would they know it's a brand new computer vs all upgraded parts?
If I bought either of these, could I create a USB installer so that I don't have to buy an optical drive? Is there a good guide for this?
I think it generates a unique hardware ID or something. There is limited number of times where it can be reactivated online, after that you must call to reactivate.
If you buy either of these, yes you can create a USB installer, just run the Microsoft's media creation tool
http://windows.microsoft.com/en-us/windows-8/create-reset-refresh-media
http://www.microsoft.com/en-us/download/windows-usb-dvd-download-tool
Great. Thanks for all the info!
I think it's in the TOS that the OEM version of Windows 8.1 is intended to be installed, then resale to a customer. Unlike Windows 8, where you're allowed to use OEM version for personal use, Windows 8.1 require you to use full retail version for that.
Building a PC in a month time, was thinking if I should save the money by going with OEM, sell the pc to my girlfriend for three "don't-nag-me" vouchers, and buy it back for three "scrub-the-bathroom" vouchers.  Or just suck it up and get retail versions.
Price difference here is worth a copy of cities skylines (or 50 humble bundle titles).
Sucks not allowed to use MSDN licenses for personal use... :(
