You could try to do an A6 or A8 based computer. Let me see what I can throw together.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/329263-minecraft-box/#findComment-4470091
This will get you some frames in the Minecraft and the Garry's mod and what not http://pcpartpicker.com/p/TfyJ23
I think that a build with an i3 and a cheap motherboard would be better for Minecraft because better single core performance.
Sig under construction.
https://linustechtips.com/topic/329263-minecraft-box/#findComment-4470121
Alright. Here we are. I didn't have the money to get an OS, but I think this should do everything nicely.
CPU: AMD A8-6600K 3.9GHz Quad-Core Processor  (£69.01 @ CCL Computers)
Motherboard: Gigabyte GA-F2A88XM-DS2 Micro ATX FM2+ Motherboard  (£40.30 @ Amazon UK)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  (£33.85 @ Scan.co.uk)
Power Supply: be quiet! 300W 80+ Bronze Certified ATX Power Supply  (£31.64 @ Aria PC)
Total: £289.63
Generated by PCPartPicker 2015-03-16 19:19 GMT+0000
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/329263-minecraft-box/#findComment-4470153
Total: £289.63
Thanks linux will do what is needed of it
https://linustechtips.com/topic/329263-minecraft-box/#findComment-4470193
Anyways here is an Intel i3 build it is a little bit over 300 but it will give you better performance since there is a seperate dedicated GPU which will put a boost into the FPS. http://uk.pcpartpicker.com/p/mGkFyc
https://linustechtips.com/topic/329263-minecraft-box/#findComment-4470263
You could at least give him the latest plattform not last gen.
PCPartPicker part list: http://uk.pcpartpicker.com/p/CBrT3C
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  (£89.97 @ Amazon UK)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  (£33.72 @ CCL Computers)
Memory: Corsair Vengeance 4GB (2 x 2GB) DDR3-1600 Memory  (£30.59 @ More Computers)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive  (£34.74 @ Aria PC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  (£109.99 @ Amazon UK)
Case: Fractal Design Core 2300 ATX Mid Tower Case  (£28.50 @ Scan.co.uk)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  (£40.25 @ Aria PC)
Total: £367.76
Generated by PCPartPicker 2015-03-16 19:54 GMT+0000
https://linustechtips.com/topic/329263-minecraft-box/#findComment-4470458
Hey guys im looking for a pc to play minecraft and maybe play other games like gmod ect. It would want to be about £300 maybe a little more but no peripherals or os are required. Thanks in advanced. :)
Try This:
https://linustechtips.com/topic/329263-minecraft-box/#findComment-4520179
