V sync Causing audio crackling
Go to solution Solved by GETxHIPFIREDx,
Unless his PSU is faulty, which I don't think it is (it could be), it's entirely sufficient for his card.
I haven't experienced the same problem again since switching to an ASUS 970 running on a DVI cable, with audio going over the motherboard via a headphone jack. Now I just have a slow POST problem that I suspect is either memory or PSU related.
Just got some memory back from RMA, completely replaced. Gonna test it on another rig first and see what happens.
 i reinstalled windows and im good. slight problems no where near the old problems
specs in sig/profile
so in a lot of game i will play if i v sync enabled the audio crackles. even in games when im getting 100+ fps.
i have updated audio drivers on my motherboard and graphics card driver as well ( clean install)
i have no idea where to start. if you have and questions please ask and ill awnser
CPU- Intel i9 9900k | Motherboard- ASUS ROG Strix Z390-I | RAM- Kingston HyperX 32GB | GPU- Nvidia 2080ti Reference
Case- NCase v6.1 | Storage- x2 2tb WD m.2  | PSU- Corsair SF750 | Cooling- NZXT Kraken X52
https://linustechtips.com/topic/328778-v-sync-causing-audio-crackling/
Buy a cheap sound card like a xonar DG or DX and that will fix it instantly
That is very strange. They are two different things... It could be the electrical noise from the GPU that affects the sound when it's working hard. Have you tried using headphones to see if it still crackles?
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
i put my brothers sound card in to see and it didnt work
Yes ive tried my big headphones and iphone headphones
i called asus and nvidea and they both just said to update drivers :(
no help at all
Download LatencyMon and have it running while the issue is present.
Post results here.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
Post results here.
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for  0:00:47  (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name:                                        HIPFIRED-PC
OS version:                                           Windows 7 Service Pack 1, 6.1, build: 7601 (x64)
Hardware:                                             All Series, ASUS, ASUSTeK COMPUTER INC., Z97-A
CPU:                                                  GenuineIntel Intel® Core™ i7-4770 CPU @ 3.40GHz
Logical processors:                                   8
Processor groups:                                     1
RAM:                                                  8134 MB total
CPU SPEED
Reported CPU speed:                                   3398.0 MHz
Measured CPU speed:                                   3638.0 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs):   228287.679675
Average measured interrupt to process latency (µs):   165.068921
Highest measured interrupt to DPC latency (µs):       12269.066036
Average measured interrupt to DPC latency (µs):       110.071455
 REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs):              76.50
Driver with highest ISR routine execution time:       dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%):          0.159023
Driver with highest ISR total time:                   dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%)                          0.301526
ISR count (execution time <250 µs):                   235890
ISR count (execution time 250-500 µs):                0
ISR count (execution time 500-999 µs):                0
ISR count (execution time 1000-1999 µs):              0
ISR count (execution time 2000-3999 µs):              0
ISR count (execution time >=4000 µs):                 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs):              26049.955562
Driver with highest DPC routine execution time:       USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%):          19.768694
Driver with highest DPC total execution time:         USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Total time spent in DPCs (%)                          25.145191
DPC count (execution time <250 µs):                   331202
DPC count (execution time 250-500 µs):                0
DPC count (execution time 500-999 µs):                122902
DPC count (execution time 1000-1999 µs):              10612
DPC count (execution time 2000-3999 µs):              2034
DPC count (execution time >=4000 µs):                 0
 REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count:                 searchindexer.exe
Total number of hard pagefaults                       173
Hard pagefault count of hardest hit process:          151
Highest hard pagefault resolution time (µs):          88307.473808
Total time spent in hard pagefaults (%):              0.069255
Number of processes hit:                              5
 PER CPU DATA
CPU 0 Interrupt cycle time (s):                       24.521445
CPU 0 ISR highest execution time (µs):                64.277810
CPU 0 ISR total execution time (s):                   0.312895
CPU 0 ISR count:                                      93672
CPU 0 DPC highest execution time (µs):                12849.718658
CPU 0 DPC total execution time (s):                   24.083824
CPU 0 DPC count:                                      197108
CPU 1 Interrupt cycle time (s):                       13.501680
CPU 1 ISR highest execution time (µs):                63.324897
CPU 1 ISR total execution time (s):                   0.143265
CPU 1 ISR count:                                      25026
CPU 1 DPC highest execution time (µs):                16947.905238
CPU 1 DPC total execution time (s):                   13.314422
CPU 1 DPC count:                                      49540
CPU 2 Interrupt cycle time (s):                       9.810479
CPU 2 ISR highest execution time (µs):                76.50
CPU 2 ISR total execution time (s):                   0.151194
CPU 2 ISR count:                                      24760
CPU 2 DPC highest execution time (µs):                26049.955562
CPU 2 DPC total execution time (s):                   9.626558
CPU 2 DPC count:                                      44166
CPU 3 Interrupt cycle time (s):                       18.266670
CPU 3 ISR highest execution time (µs):                60.464979
CPU 3 ISR total execution time (s):                   0.157372
CPU 3 ISR count:                                      28558
CPU 3 DPC highest execution time (µs):                25260.583579
CPU 3 DPC total execution time (s):                   17.838464
CPU 3 DPC count:                                      56751
CPU 4 Interrupt cycle time (s):                       6.80620
CPU 4 ISR highest execution time (µs):                70.004709
CPU 4 ISR total execution time (s):                   0.100844
CPU 4 ISR count:                                      16078
CPU 4 DPC highest execution time (µs):                16325.493820
CPU 4 DPC total execution time (s):                   6.611276
CPU 4 DPC count:                                      30565
CPU 5 Interrupt cycle time (s):                       12.434845
CPU 5 ISR highest execution time (µs):                66.108299
CPU 5 ISR total execution time (s):                   0.135267
CPU 5 ISR count:                                      23516
CPU 5 DPC highest execution time (µs):                17643.380224
CPU 5 DPC total execution time (s):                   12.040887
CPU 5 DPC count:                                      42138
CPU 6 Interrupt cycle time (s):                       6.546925
CPU 6 ISR highest execution time (µs):                58.462919
CPU 6 ISR total execution time (s):                   0.072954
CPU 6 ISR count:                                      12106
CPU 6 DPC highest execution time (µs):                14732.699235
CPU 6 DPC total execution time (s):                   6.227244
CPU 6 DPC count:                                      26259
CPU 7 Interrupt cycle time (s):                       6.973041
CPU 7 ISR highest execution time (µs):                58.571218
CPU 7 ISR total execution time (s):                   0.078087
CPU 7 ISR count:                                      12174
CPU 7 DPC highest execution time (µs):                16000.683343
CPU 7 DPC total execution time (s):                   6.315978
CPU 7 DPC count:                                      20892
CONCLUSION
SYSTEM INFORMATION
Processor groups:                                     1
RAM:                                                  8134 MB total
CPU SPEED
 REPORTED ISRs
REPORTED DPCs
 PER CPU DATA
Thank you for the spoiler tag xD
Try this.
Set your power mode to "High performance" and your minimum processor state to 100%.
I always do this when I install windows.
From the log, it looks like USBPORT.sys is causing the issue. Try re installing the drivers for your motherboard; including the chipset drivers, and the intel rapid storage utility.
I actually had this issue too; but from a different driver. I swapped hardware a stupid amount of times to the point where I had the same specs but only my PSU was original. It ended up being an AMD driver issue with crossfire.
Try this.
I re installed  audio,chip set,and usb. as well as, setting the power setting to the right things. when i installed the Intel rapid storage thing i got a message saying my computer didn't meet the minimum specs? it having problem
CONCLUSION
LatencyMon has been analyzing your system for  0:05:11  (h:mm:ss) on all processors.
SYSTEM INFORMATION
CPU:                                                  GenuineIntel Intel® Core i7-4770 CPU @ 3.40GHz
Processor groups:                                     1
RAM:                                                  8134 MB total
CPU SPEED
Reported CPU speed:                                   3501.0 MHz
Measured CPU speed:                                   4201.0 MHz (approx.)
Highest measured interrupt to process latency (µs):   71114.346345
Average measured interrupt to process latency (µs):   141.071707
Highest measured interrupt to DPC latency (µs):       13182.830618
Average measured interrupt to DPC latency (µs):       135.534785
 REPORTED ISRs
Highest ISR routine execution time (µs):              216.543559
Highest reported total ISR routine time (%):          0.151498
Total time spent in ISRs (%)                          0.19720
ISR count (execution time <250 µs):                   939461
REPORTED DPCs
Highest DPC routine execution time (µs):              9195.817481
Driver with highest DPC routine execution time:       iusb3xhc.sys - Intel® USB 3.0 eXtensible Host Controller Driver, Intel Corporation
Highest reported total DPC routine time (%):          3.926076
Driver with highest DPC total execution time:         iusb3xhc.sys - Intel® USB 3.0 eXtensible Host Controller Driver, Intel Corporation
Total time spent in DPCs (%)                          6.271070
DPC count (execution time <250 µs):                   1985622
DPC count (execution time 500-999 µs):                71627
DPC count (execution time 1000-1999 µs):              38290
DPC count (execution time 2000-3999 µs):              16094
Process with highest pagefault count:                 avgrsa.exe
Total number of hard pagefaults                       22744
Hard pagefault count of hardest hit process:          12090
Highest hard pagefault resolution time (µs):          501173.811197
Total time spent in hard pagefaults (%):              1.251587
Number of processes hit:                              22
 PER CPU DATA
CPU 0 Interrupt cycle time (s):                       159.661913
CPU 0 ISR highest execution time (µs):                216.543559
CPU 0 ISR total execution time (s):                   4.921401
CPU 0 ISR count:                                      939461
CPU 0 DPC highest execution time (µs):                9195.817481
CPU 0 DPC total execution time (s):                   155.676453
CPU 0 DPC count:                                      1939522
CPU 1 Interrupt cycle time (s):                       0.816518
CPU 1 ISR highest execution time (µs):                0.0
CPU 1 ISR total execution time (s):                   0.0
CPU 1 ISR count:                                      0
CPU 1 DPC highest execution time (µs):                37.610683
CPU 1 DPC total execution time (s):                   0.089027
CPU 1 DPC count:                                      19130
CPU 2 Interrupt cycle time (s):                       1.014543
CPU 2 ISR highest execution time (µs):                0.0
CPU 2 ISR total execution time (s):                   0.0
CPU 2 ISR count:                                      0
CPU 2 DPC highest execution time (µs):                31.356755
CPU 2 DPC total execution time (s):                   0.229448
CPU 2 DPC count:                                      43423
CPU 3 Interrupt cycle time (s):                       0.704519
CPU 3 ISR highest execution time (µs):                0.0
CPU 3 ISR total execution time (s):                   0.0
CPU 3 ISR count:                                      0
CPU 3 DPC highest execution time (µs):                30.942873
CPU 3 DPC total execution time (s):                   0.070598
CPU 3 DPC count:                                      15606
CPU 4 Interrupt cycle time (s):                       0.942481
CPU 4 ISR highest execution time (µs):                0.0
CPU 4 ISR total execution time (s):                   0.0
CPU 4 ISR count:                                      0
CPU 4 DPC highest execution time (µs):                31.758926
CPU 4 DPC total execution time (s):                   0.175247
CPU 4 DPC count:                                      37771
CPU 5 Interrupt cycle time (s):                       0.673713
CPU 5 ISR highest execution time (µs):                0.0
CPU 5 ISR total execution time (s):                   0.0
CPU 5 ISR count:                                      0
CPU 5 DPC highest execution time (µs):                115.160526
CPU 5 DPC total execution time (s):                   0.042045
CPU 5 DPC count:                                      7957
CPU 6 Interrupt cycle time (s):                       1.161759
CPU 6 ISR highest execution time (µs):                0.0
CPU 6 ISR count:                                      0
CPU 6 DPC highest execution time (µs):                30.207655
CPU 6 DPC total execution time (s):                   0.205608
CPU 6 DPC count:                                      43154
CPU 7 Interrupt cycle time (s):                       0.609646
CPU 7 ISR highest execution time (µs):                0.0
CPU 7 ISR count:                                      0
CPU 7 DPC highest execution time (µs):                38.866038
CPU 7 DPC total execution time (s):                   0.014901
CPU 7 DPC count:                                      6271
CONCLUSION
SYSTEM INFORMATION
Processor groups:                                     1
RAM:                                                  8134 MB total
CPU SPEED
 REPORTED ISRs
REPORTED DPCs
 PER CPU DATA
CPU 1 ISR count:                                      0
CPU 2 ISR count:                                      0
CPU 3 ISR count:                                      0
CPU 4 ISR count:                                      0
CPU 5 ISR count:                                      0
CPU 6 ISR count:                                      0
CPU 7 ISR count:                                      0
Okay; Check for a BIOS update, and re install your GPU driver.
And don't worry about the Intel Rapid storage driver; Not for your system.
updated to latest bios and did a clean install with the latest gpu drivers
still crackling
still crackling
Hmmm. Try it without the GPU; clean install again, and install one driver at a time.
After each driver, check with Latencymon
I had a similar problem with a gtx 660 EVGA ftw edition card. It had nothing to do with V-sync though.
From what I managed to figure out, it was one of two things,
either my PSU was not good enough for EVGA's card, which is what EVGA claimed when they RMA replaced my GTX660, and the problem continued,
or
EVGA's ftw cards just suck for some reason.
Dubs are better than subs
or
Is DPC Latency still through the roof?
disable/uninstall ANY and ALL sound rivers you are not using. you may have 3 different ones installed creating conflict.
you mentioned heasdphones above............ do what I previously said. don't install anything for the headphones yet. see how things go.
If it works and you need a driver for the headphones, install and see how that effects.
disable windows auto driver updates and windows updates first.
nope
nope
Great! Mark the topic as solved please!
