So my friend has had his computer for a month now and he has a 750gb seagate momentus that I think is failing, when he goes into computer it doesn't show the disk space and when he goes to enter into the hard drive it takes 2 minutes to load then says parameter is incorrect. Sometimes the hard drive doesn't show at all. Anyone got any suggestions what it is and how to fix?
https://linustechtips.com/topic/328240-hard-drive-failure/
check it with crystaldiskinfo
it willl tell you if its failing
https://linustechtips.com/topic/328240-hard-drive-failure/#findComment-4456305
what operating system?
did he try the HD utility to see if it's up to par? (seagate site )
what hardware?
He uses windows 7 professional and he has:
i5 4690k
MSI g45 gaming mobo
Asus strix 970
8gb vengeance lp
120gb Intel 530 ssd
750gb Seagate momentous
Fractal design 600w
I will run the tests tomorrow because its 11:30PM in England thanks guys will tell ya the results
Forgot to say, I doubt he even knows Seagate have a HD utility so no he hasnt xD
https://linustechtips.com/topic/328240-hard-drive-failure/#findComment-4456658
