First Build, everything connected, nothing happens
Hi guys,
I just put my very first pc together but somehow nothing happens and yes I switched Power-Switch to "On".
My Graphicscard has a green LED lit on, but that's about it.
The DVD-Drive won't open, no fans are running and I don't get any feedback of anything....
Well I still have to apply the frontpanel-connectors the right way but still....
Little Checklist of what I've connected:
1. Motherboard is installed, 24-Pin-Connector and CPU-4-Pin-Connector are attached aswell.
2. CPU and CPU-Fan are installed, Fan-Connector is also applied.
3. RAM-Stick and GPU are installed, 6-Pin-Connector is applied to the GPU
4. HDD and DVD-Drive are connected via sata to the mb and and via sata x6 to the psu
5. psu is on
6. Front-Panel-Connectors still have to be applied properly...
7. Fans are applied to the mb
I just think that it is wierd, that the drive won't even react...
Well I first going to find out how to apply the front-connectors properly and write then again.
Until then, maybe you could give me some hints at what I might have forgotten or what I should check on.
Greetings
what?! if this isn't setup correctly IT WON'T TURN ON
