A continue from this thread, I'm thinking on running fan speeds at their minimum when PC is idling. I wonder if this can be harmful to the fans (like not designed for such low speeds).
In SpeedFan I can configure speeds lower than 60%, but RPM fluctuates a lot, sometimes reporting 0RPM when they are still working, I would probably want to set them up to 50 or 40%, and only raise when GPU is getting hot. I own an Asus Gryphon Z87, a NF-P12 and a Bitfenix Spectre 230mm.
Another question is about speed graph in Fan Control. There are too many knot points to set when I find that only 4 could be enough. Can this be configured at all, since it's very time consuming whenever I want to change the graph.
https://linustechtips.com/topic/327491-minimum-fan-speeds/
it depends on the fan
if you notice its fluctuating a lot then dont put it so low
PWM fans can typically go down to 20 or 30% while 3 pin voltage control fans usually have a 40 or 50% minimum
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4447946
Fans are PWM, but they are connected to 3 pin plugs in the mobo since the Gryphon (and I assume most mainstream boards) rarely have more than one real PWM header, which I decided to reserve to the CPU fan. Here I want to control the 2 other fans for the case.
you say the minimum for 3pin is 40 or 50%, what happens if you set them lower than that?
As a side note, I read this here. "One downside to SpeedFan (and others): the BIOS settings typically have to be "full on", which means that the fans run full tilt each time you reboot until you log in and SpeedFan starts up."
When using SpeedFan, do I have to disable BIOS fan control?
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4447987
Fans have a starting voltage which is normally 5-6volts they will not spin any slower than this with out the possibility of them stopping
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4448376
How do I know the minimum rotational speed at 5 or 6 volts?
edit: I read this somewhere else: "in analog mode (3pin), it's just the voltage percentage of 12v. So 6v would be 50% speed."
But I don't know if that percentage correlation applies to SpeedFan as well.
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4448579
On 60% it spins at 540RPM
if I set the minimum speed to 50% it drops to 300RPM and fluctuates a bit, sometimes reporting 0RPM.
leave it on 60% if you can then. You feel like you need more crank them up. I have mine 50% till 50c on cpu then they kick up. If you set them to low they can click.
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4449052
Yeah, the problem as I said is that the noctua can only go as low as 60% without losing stability.
The case is dampened with foam, although most of the noise gets out from the aperture of the Noctua exhaust fan, close by is the GPU, so it must be one of those 2. The Spectre 230mm shouldn't do a very high freq noise, so I ruled it out. (edit: and the PSU is fanless)
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4449170
it's a PWM fan plugged into a board 3 pin header.
There's only one PWM controller on board and it is assigned to CPU fan, the one I got for the radiator.
ah change them your rad will be fine on voltage only i think. If all else fails split those suckers. Use pmw for pmw fans, it should be able to go lower.
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4449378
Thanks man, splitter, sounds good. Splitter or a proper 3 pin fan I guess, I was told PWM fans don't go well on 4 pin headers (at low voltages)
pmw gives it 12v the whole time. It modulates the width of the wave, google it its cool shit. No problem, a proper 3 pin and low voltage adapter can give really low noise and rpm. Also i would just grab a splitter, you have one of the better fans on the market, hard to go up.
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4449507
I will do the cheapest, probably the splitter. I hope with that the fan keeps stable at 40% or even less.
I guess with a 3 pin fan SpeedFan could unlike the 4 pin fan modulate voltage, even without LNA adapter, but I'm not sure on that.
http://www.amazon.com/JBtek%C2%AE-Sleeved-Splitter-Cable-Converter/dp/B00OZ10FI2/ref=sr_1_1?ie=UTF8&qid=1426288159&sr=8-1&keywords=4+pin+fan+splitter
they may be cheaper from something like monoprice, i would just get them locally if you can.
the lower rps the less air they move, after a point they move almost nothing. i think a good 3 pin with voltage adapter can get to 20% but, i'm not sure too :) never did it.
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4449667
With voltage adapter you mean cable or fan controller?
Today components are so power optimized that I don't think there's much need to spin fans on idle. Only GPU and CPU. I will try with 40% or 30%.
For GPU I guess the only way is to patch firmware, I already did patch it, as the 750 Ti seems to be power throttled (over 38 watts it would throttle), but it's not something I enjoy doing.
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4449757
depends on temps. i think we are talking about the same thing, something you already tried. fpr gpu if you already have a custom fan curve set and its at its lowest  not much you can do besides mod the bios (don't), mine is a 34%.
the may be cheaper from something like monoprice, i would just get them locally if you can.
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4450120
Yes I was already reading about modding the BIOS around here. I already modded the BIOS of the 750 Ti, as I said because the core clock was power throttled, I just checked the kepler bios tweaker (the maxwell II tweaker won't work on 750 Ti) and it doesn't allow to change fan speeds, not sure if because hardware locked, or because the tool is kepler oriented.
The default minimum fan speed is 40%, but at idle this GPU is very cool ~30ºC. 30% could be good.
https://linustechtips.com/topic/327491-minimum-fan-speeds/#findComment-4450158
