Separate volume control dials.
Go to solution Solved by Enderman,
Two reasons. I'm lazy :D and there are times when i'm playing a game or running a full screen program and dont want to go to the desktop to select a slider and do all of this other nonsense; and no my keyboard does not have volume control on it either.
k then get something like this
http://www.amazon.ca/Griffin-Technology-NA16029-Multimedia-Controller/dp/B003VWU2WA
https://www.google.ca/#q=usb+volume+knob
My speakers are cheap and don't have a volume control dial on them (a mistake on my part). Does anyone make a stand alone volume control dial or are they only bundled with sound cards?
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
https://linustechtips.com/topic/325912-separate-volume-control-dials/
uh, why cant you just change the volume in windows?
You're welcome :)
Technically, just get a good pots (potentiometer), and install it in the middle of the speaker input cable. Can even dress it up with a fancy box and knob.
Syba DAC is cheaper in the US, and has more functionality than a simple USB windows volume control.
Is PC audio routed through USB on this DAC?
Of course.
Also, I couldn't remember who made this last time I posted, but this is more for what you're describing: http://www.amazon.com/Volume-Controller-Fostex-Pc-1e-White/dp/B0058B1T4M
