Hello Guys,
So I'm in the process of RMA'ing my 3rd dead Swiftech H320 to NCIX and this time I'll have the option to pick out a different cooler. I'm definitely NOT interested in any sort of custom loop so I'm wondering if I should try another AIO water cooler, or just go back to an air cooler?
Either way, I'm looking for suggestions for either a more reliable AIO (I was thinking Corsair, but I'm no expert, clearly) or a quiet-ish Air Cooler (possibly a BeQuiet!). I can fit up to a triple rad in the top of my 750D (I originally went with the H320 because it was basically the only triple-rad AIO) and already have some good Cougar fans and a splitter. Let me know if you need any more info, specs are in my sig.
For those who care about the dead H320's: http://linustechtips.com/main/topic/218766-swiftech-h320-pump-noise-6-months/
HexCase: Corsair iCUE 5000X RGBCPU: Ryzen R7 3700X  | MOBO: Asus TUF Gaming X570-Plus | GPU: Gigabyte RTX 2070 Super | RAM: G.SKILL Ripjaw DDR4-3600 16GB | SSD: Corsair MP600 1TB & 480 GB EVO | HDD: 4tb WD Black & 3TB WD Green | PSU: EVGA SuperNOVA 850 G+ | Cooler: CORSAIR iCUE H100i RGB PRO XT, | Monitor: Acer Predator X34 | Keyboard: Corsair K70 RGB | Mouse: Logitech Hero | OS: Windows 11 | Speakers: Audioengine A5+ | Headset: Kingston HyperX Cloud 2 | Laptop/Tablet: TBD | Phone: Samsung Note 9 | PS4 | Xbox One | TV Sony XBR55X900F
https://linustechtips.com/topic/325576-dead-h320-cooler-recommendation/
Hello Guys,
Noctua. My 5820k overclocked to 4.7ghz never goes over 73 degrees with an NH-D15.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
I've been using a Kraken x60(You probably won't find it retail, except for maybe on Amazon) for two years now. My PC is on 24/7. I imagine the Kraken x61 won't be much different in that regard.
I doubt it's AIOs fault in general.. There are plenty people on this site who have had AIOs for a long time with 0 problems...
It's not AIOs in general, but I do recommend the Cryorig R1 Ultimate or the be quiet! Dark Rock 3. They perform as well and possibly better than 240/280MM AIOs and have a single point of failure (if you don't count the mounting hardware.).
d14 can be had for cheap if you can fit it on you mobo/case
d15 is very good performer but a bit more expensive
both have great mounting
there are other high performance dual tower air coolers, as mentioned cryorig is cheap
for single tower you can get phanteks 12cm one, cheap and great performer ( dual fans )
I really like my h105 from corsair. I've had it for a while now and no issues. The pump is louder than I'd like but quieter than other AIO's. I don't recommend using the stock fans with it tho, you should replace them with something quieter.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
or if the rads have standard fittings you might want to gehto rig a custom loop
CPU: I7 8700k @ 5ghz | Motherboard: Asus Z370-Prime | RAM: White Crucial balistix DDR4 2133mhz | GPU: GTX 1080TI | Storage: ssd HyperX 240gig, 2x2tb seagate Firecuda 1tb, BPX 480 gig nvme, 1tb sandisk ssd  | Cooling: Custom loop | PSU: Evga supernova 850w G2 | Case: Phanteks enthoo evolv atx black White modded | system theme: White/RGB/Weiss
O forgot to mention, I don't mind an expensive cooler and I really want something quiet, my system runs near-silent besides the cooler.
I've had a Noctua D14, and it cooled great but was much louder then I like.
Wonder if I posted this in the Air Coolers sub-forum if the poll would be different ;)
Anyway, any more recommendations out there?
Think I'm going to go with Corsair's H100i GTX, under the assumption that it's better then the normal H100i
