Best dual card
Go to solution Solved by 1Scotty1,
2x 970 is 70-80% more over a single 980, so go 970s
Hi there awesome people !!
Guys i was going to buy Gtx 980 but i think i can get 2x 970 or somethign for the alsmost same price or for little bit more price so can u please tell me the exacly model.
Feel free to post anything that is on your mind.
I will use 1080, 144hz 1ms ( if possible with G=Syng monitor ) [sINGLE MONITOR]
Project Redline:
♦CPU: i7-5820k  ♦CPU Cooler: Kraken x61 ♦Mobo: MSI X99A SLI ♦RAM: G.Skill Ripjaws 4x4GB 3200mhz ♦GPU: Evga 980Ti Hybrid ♦Case: NZXT H440 ♦SSD: Samsung 850EVO 500GB ♦HDD: WD BLUE 1TB 7200rpm ♦Display: 1280 x 1024
https://linustechtips.com/topic/325516-best-dual-card/
I have 2 970's myself bit mor expensive than 1 980 but a really nice combo!
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4420998
Well its not that much single 980 is 1400BGN here and one Asus GTX 970 STRIX is 800BGN
Project Redline:
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421005
The general advice is to go with the best single card you can afford with your budget, because with 2 you'll have to factor in the extra heat and power consumption. I'd say, go for the 980 if you don't have anything yet.
New to Star Citizen? Look no further!
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421007
I buy my computer summer :D when school is done [ dont say that now "dont plan your build for summer from now" ]
And btw power is not problem for me
Project Redline:
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421012
Don't plan your computer for summer new :P
Hm, you can hold off for it right now. There might be a new lineup with better performance for the price when you actually start buying.
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421025
If u say so :D because my budjed is 3000BGN or 3300 BGN :D something like this
Project Redline:
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421030
That applies UNLESS you're talking about 970s.. Then it changes..
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421037
How so? Is the performance increase really that noticeable over the 980?
I think it's 10-15% more for 30-40% more performance.
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421051
ya actually is it 40% ot 50% more ?
Project Redline:
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421052
ohh so its not worth is it ?
Project Redline:
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421057
Lol thats magnificent then !!
Project Redline:
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421082
Ty all awesome people !!!
I probally go 2 x 970  <3  [summer]
Project Redline:
https://linustechtips.com/topic/325516-best-dual-card/#findComment-4421123
