BF4 issue
Go to solution Solved by Lays,
I fixed it with gofspar, somehow it was rendering in mantle, even though I re-installed it multiple times, apparently the settings folder also wasn't being changed by Nvidia GeForce Experience when I clicked the optimize button.
Just had to delete the PROFSAVE files in documents
When I try to play BF4 I have literally 8 FPS, and if I try to open the options menu to see what the settings are or to change settings, it instantly locks up and I have to alt tab & task manager to close it.
I've tried with both GPU's as the main display out, tried with & without SLI on, tried re-installing BF4, tried repairing game files, and tried different Nvidia drivers too.
I also tried using GeForce Experience to optimize my settings, didn't work either.
Any ideas?
DSR isn't on either.
Specs:
i7 4790k
MSI M Power Z97
2133 Corsair Dominator platinum 16gb
2x G1 Gigabyte 970
EVGA 1000 P2 PSU
1x 840 Pro 256gb SSD
1x MX100 256gb SSD
https://linustechtips.com/topic/325437-bf4-issue/
When was the last time you restarted your computer?
Few days ago, it's been like this for months since I got my 970s.
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4419934
Try restarting it, try disabling SLI as well.
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4419947
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4419952
q
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4419954
Any ideas?
Specs:
i7 4790k
MSI M Power Z97
2x G1 Gigabyte 970
EVGA 1000 P2 PSU
1x MX100 256gb SSD
With FPS like that, are you sure it's not defaulting to use integrated graphics for some reason? Also what are your GPU and CPU utilizations like?
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4419964
GPU load goes to 99% and CPU goes up to, there's no reason it'd go to integrated graphics when the display cables are plugged into the GPU.
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4419992
It's obviously not related to SLI, as I've tried using SLI and disabling it and it does it both times.
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4420002
Good point haha. Is there an option for renderer? Like DX, Mantle, OpenGL, etc
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4420050
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4420067
Do you have Rivatuner stat server running in the background?
-If so then try running BF4 after disabling rivatuner entirely. Rivatuner can, in some cases, cause extreme slowdowns when a game detects it.
Have you tried physically removing one of the cards and running with only one card in the system?
-Also try swapping which card is in the system and which slot it's in.
Glad you figured it out.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4420085
970S? GeForce 970 has Vram problems.
It's not a "problem"; it's by design. The only "problem" would be the miscommunication between the engineers and marketing.
Also, he's fixed the issue by deleting residuary files.
https://linustechtips.com/topic/325437-bf4-issue/#findComment-4420260
