CPU Fan help! Will it fit/work?
Solved by Enderman,
He said "cheap" not go into debt over.
READ
I was thinking, I will be doing all from videoediting to gaming, after checking things out I feel like that cooler wont be enough.. and scrap that 'as cheap as possible' part. I want something that keeps my cpu together. Maybe not a coolermaster h100 for 100$ but still why not. Any suggestions?
The NH-D14 is about $80 or less and performs much better than a hyper 212 evo. Its also a very quiet cooler that you can overclock on.
