3 pin vs Pwm
Solved by Aniallation,
So I have an Asus mother board that comes with in built software that controls fan speed based on temps - this is currently working with my 3 pins fans as well as my pwm fan - so is there any point in spendong a not extra on a pwm?
PWM fans have more accurate control and can hit lower speeds (usually minimum is 20% for PWM while DC control can for the most part only go down to around 40-50%)
