Hi guys was just wondering if my current PC can play BF4 , i know they havent released recommended specs yet but want some feed back :)
MY PC specs :
AMD Phenom ii x4 965 @3.8ghz
EVGA GTX660 Sc ( non ti )
8gb Corsair XMS3
Gigabyte GA-970a-ds3 mobo
thanks in advance :)
My Pc Specs
CPU : AMD FX-8350 @stock w/Noctua NH D-14   Mobo: Asus M5A99FX    Ram : 16gb Corsair XMS3 @1600mhz    GPU : Gigabyte GTX970 Windforce OC 4GB @1429mhz   SSD: Sandisk X110 256gb    Case: Be Quiet Silent Base 800 Windowed  PSU: EVGA 850w g2  Peripherals : Corsair K70 w/Red Switches , Logitech G502 , Samsung SyncMaster S22B300 (1920x1080) , Ttesports Shock one headset , Phone : HTC one A9
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/
I'm not sure but I've heard that BF4 will make the 660 cry on its knees.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414691
MY PC specs :
8gb Corsair XMS3
O: we almost sorta kinda have the same specs xD same gpu and cpu and almost same OC :D i hope it can run it max :(
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414706
we wont be able to go max settings on BF4 :( , i was thinking about getting a 7950 , then another one later on just before BF4 comes out
My Pc Specs
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414718
Says who, everything we have seen is pre alpha benchmarks, if it can't max it i'll be pissed, i'm 15, i can't afford to upgrade >_<
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414731
HD9000 series come around when bf4 comes out.
CPU: Intel Core i5 2500K 4,6GHZ OC MB: MSI Mpower z77  RAM: Kingston Genesis 1600Mhz CL9 16GB
GPU: ASUS R9 290 Direct CUII  PSU: Corsair AX 860
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414743
yea im only 18 , ill be saving for a few months to get my 2x 7950's
My Pc Specs
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414747
The game isn't out yet so we don't know, my guess is Yes but on Low settings. (Guess based on absolutely nothing)
CPU : Intel Core i7 3960X, Mobo : X79-UD3, Memory : 4x4GB Vengeance Black Memory 1600MHz, GPU : Asus GTX 970 Strix, Case : Switch 810 Matte Black, Storage : 256GB Samsung 830 SSD, Seagate Barracuda 1TB, PSU : Thermaltake 750W 80+ Bronze, Displays : 3x Asus 1080p Screens, Cooling : Corsair H100i, Keyboard : Logitech G710+, Mouse : Madcat Cyborg R.A.T.7, Sound : Sennheiser HD598, V-Moda Crossfade LP, Logitech Z-5500, HMD : Oculus Rift CV1
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414750
you should "lend" me your old 660 :DD
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414754
Haha sadly not , my old 660 will go into my brothers PC , so he dosent have to keep using my PC for borderlands 2 and BF3
My Pc Specs
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414761
i can be your brother  :ph34r:
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414766
my answer ... yes it will fun and smoothly too but you wont be maxing out the eye candy
(1) high frame rate (2) ultra graphics settings (3) cheap...>> choose only two<<...
if it's never been done then i'm probably tryna do it. (((((((Bass so low it HERTZ)))))))
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414829
Btw, just wondering, can you get the CPU to 4.0 Ghz? and what voltage are you using to sustain that 3,8 OC? I have mine @ 4.0 and voltage cranked waaay higher than recommended :D
mine is at 3.9ghz with 1.104 volts, i get bsod with 4ghz :(
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414876
CPUz says that my voltage is from 1,550 to 1,578 but i realllllly wanted it to go to 4.0 so i'm willing to push more voltage. Bios shows 1,6 tbh :D idk what to trust, but it's stable 24 hours of prime 95, small, large and blend - not a single fail  :)
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-414917
im at 3.8 ghz on 'standard' voltage
My Pc Specs
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-415171
Really none of the benchmarks matter to me as long as I'm getting 60 FPS in multiplayer I'm happy as I run BF3 64 player at medium with all the options that affect performance. I can play @ ultra but the framrate dips to 30-40 FPS. I use a 1600X1200 Dell monitor.
CPU: AMD 3600 GPU: ASUS DUAL OC RX 6750 XT MOBO: Asus Prime X570-P RAM: 16GB XPG Gammix D10 3000Mhz
PSU: Gamdias Kratos P1 650w 80+ Gold OS:Windows 10 pro Case: 4U Rackmount  HDD/SSD:Seagate 8 TB/ Patriot Scorch m.2 512GB
You can't spell ignorant without IGN...-TheSLSAMG
https://linustechtips.com/topic/32443-will-my-current-pc-ply-bf4/#findComment-416490
