What should I do:
1) get a gtx 770 to pair with my other 770
2) get 2 gtx 970 to use in my main rig and replace the gtx 550 in my media pic with the 770 that is currently sitting in my rig
<THE SILENT ASSASSIN>CPU(Intel i5-4690K)||COOLER(corsair H100i)||MOB(asus Maximus VII Hero ATX)||RAM(16gb of corsair vengeance)||STORAGE(Intel 530 128gb)(Samsung 850 Pro 500gb)(WD 2tb Black)||GRAPHICS(2 x Asus strix 970)||CASE(Nzxt H440)||PSU(Corsair RM750W)>http://pcpartpicker.com/b/Bbpbt6
https://linustechtips.com/topic/321300-i-need-help/
What should I do:
Welcome to the forums!
Obviously, two 970's will wreck two 770's.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/321300-i-need-help/#findComment-4367126
GTX 970s.
But if you want, dual 290xs or a 295x2 is better
Sorry I'm part of the green team
https://linustechtips.com/topic/321300-i-need-help/#findComment-4367135
depends on how much money you want to spend lol
exactly what he said.
for gaming at 1080p dual 770's will wreck almost any game (unless you use 8xAA, 2gb of ram is not enough for that)
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/321300-i-need-help/#findComment-4367140
The 2 970 are around 600
The 1 770 is around 450
If I choose the 770 I'll have to deal with the 550 in my media rig
https://linustechtips.com/topic/321300-i-need-help/#findComment-4367158
GTX 970s.
OP has both the 770 and the 970 already, and the dual 290Xes and 295x2 are arguably better. Both setups trade blows at 1080p and 1440p, while at 4K the 290Xes and the 295x2 obviously pull ahead a bit.
https://linustechtips.com/topic/321300-i-need-help/#findComment-4367181
1 770 is 150 more than 1 970?
According to Amazon that I only bye from doesn't matter who I buy from
https://linustechtips.com/topic/321300-i-need-help/#findComment-4367218
Oh, sorry. I didnt see the part in which he said he had the 970...
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/321300-i-need-help/#findComment-4367255
I mean if you have the money for two 970's why wouldnt you get them?
But I would personally get a 980 for a little less and have the option to add another and only deal with the scalling of two 980's verses three 970.
I think the scaling of 2 970 is greater than the scaling of one 980
I may be wrong
https://linustechtips.com/topic/321300-i-need-help/#findComment-4367300
I may be wrong
With just one 980 yes two 970 can be better. But what I meant is that in the future when you want more performance you can get another 980 and two 980 will have better scaling than three 970's
https://linustechtips.com/topic/321300-i-need-help/#findComment-4367314
I think the 970 will last a long time
https://linustechtips.com/topic/321300-i-need-help/#findComment-4367327
