Specs For modded MC?
Go to solution Solved by dadasmithywinkle,
I'm Getting A Pretty Nice PC And I Was Wondering What Specs Would I Need To Run Decently beefy mods On A MC Server.
Welcome to the forums! The CPU is what matters in MC, so get a GTX 750ti or 960 and a Core i5 or even Core i7. It may seem unbalanced, but it'd be great for MC.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4358769
Actually no. MC at heavily-modded level also requires HEAVY single threaded performence
So, i5/i7/Xeon, 8-16GB RAM, etc. If he's running shaders, a GTX 970 or R9 290X would be sufficient, if not an R9 270/GTX 760 or up should do nicely.
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4358776
This depends on your budget, but if I was going to reccomend something for that then this (others may disagree but everyone has personal choice):
CPU: Intel Core i5 4460
Mobo: A LGA1150 Socket that suits your needs but a basic of a ASUS H81M-D
CPU Cooler: Hyper 212 EVO all the way.
GPU:  GTX 760 or 960
Case: Any case that takes your fancy it it your build.
PSU: Corsair CX500M
RAM: The cheapest dual-channel 8GB kit you can get.
HDD/SSD: WD Caviar Blue 1TB and a SSD for OS if wanted.
OS: What ever OS you prefer.
People can add or reccomend different parts, but this is what I thought of just now.
My PC Specs
CPU ¦ Intel Core i5 4690k @4.3GHz, Motherboard ¦ ASUS MAXIMUS RANGER VII, RAM ¦ 8GB (2x4GB) Corsair Value DDR3, Case ¦ Corsair SPEC-02, PSU ¦ Corsair CX600, Storage ¦ Samsung 850 EVO SSD 250GB, Seagate Barracuda 500GB 7200RPM, Seagate Barracuda 2TB 7200RPM, Western Digital Caviar Green 1TB 7200RPM, Mouse ¦ Corsair Sabre RGB Optical Gaming Mouse, Keyboard ¦ Cooler Master Quick Fire TK Cherry MX Blue, Headset ¦ Astro A40 2014 with Mixamp Pro, Microphone ¦ Blue Snowball iCE.
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4358781
Id get a G3258 and a 750ti paired with 8gb of RAM, Preferibly more.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4358830
:D No AMD with MC, horrible optimization...
Ah yeah, forgot about that.
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4358838
It is hard to say, It depends on what mods, What you are doing in the background, If the moon lines up with the sun in a 32 degree angle relative to ISS.
Minecraft doesnt always make sense.
My Gaming PC
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4358841
Probably Just A Simple(ish) Modpack,and skype + 1 window probably in backround.
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4358873
Id guess between 120 and 500, Probably more.
My Gaming PC
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4358923
i reccomend a 960 super super clocked because it is only ten more dollars and has the performance of a gtx 770 for only $210, very good for a high end budget
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4358978
I know that.  That's the reason why current intel CPUs are better than AMD cpus for minecraft.  The pentium 3258 is good for minecraft on the cheap.
Linux "nerd".  If I helped you please like my post and maybe add me as a friend :)  ^_^!
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4359531
So will my 860k suck with mc?
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4359561
Modded MC, I dont know bout processors but their GPUS get low frames...
I have a FX6100 and my friend has a Phenom X6 1100T.  The X6 has much better single core performance so he gets 20-30fps more than me with the same GPU (6850).
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4359877
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4359878
You do not need a very powerful PC for minecraft even if its modded (Unless shaders) I would recommend Discrete over integrated but that is quite obvious. I have it running on my macbook air which is really underhandedly powerful :)
https://linustechtips.com/topic/320686-specs-for-modded-mc/#findComment-4359889
