R9 295X2 Power
Solved by -rascal-,
The +12V rail is one large one that can supply 70A total.You guys mean all 5 pci connecters on psu provide 12v 70 amp? each
Unlike some other PSU's, the +12V rail are several smaller ones combined. Because of this you need to balance the system.power draw evenly to prevent the over-current protection from tripping.
The RM PSU you have uses a single powerful +12V, so you do not need to balance your system load. Just plug your 8-pin PCI-E connectors in.
It's like...I have 70 gummie bears in a box. I don't care how you split it up or what you do with them, as long as you don't beg for more than 70, you're okay.
