wireless headphones for music or gaming?
for gaming, http://www.amazon.co.uk/Logitech-Wireless-Gaming-Headset-G930/dp/B003U55WWS/ref=sr_1_1?ie=UTF8&qid=1425241476&sr=8-1&keywords=g930
for audio, no idea though. im sure someone could give you a better suggestion than what i gave you.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/319904-best-wireless-headphones/#findComment-4347914
I dont want a gaming headset, Ive tried looking online I just cant find a headset I like!
https://linustechtips.com/topic/319904-best-wireless-headphones/#findComment-4365139
Sony MDR10BT
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
https://linustechtips.com/topic/319904-best-wireless-headphones/#findComment-4365355
if you want a decent headset that's wireless, you gotta go the wired route.
I'd recommend the Audio Technica M50x or the Beyerdynamic DT770 PRO
both headphones can be used for audio and gaming. For me, i'd consider getting a soundcard. unless you have a motherboard that has decent audio.
Old Rig
https://linustechtips.com/topic/319904-best-wireless-headphones/#findComment-4365782
I use this one
http://www.rapoo.com/ProductShow.aspx?PType=8fQpYH%2b%2b7i8%3d&PID=OotjJL9JOoY%3d
Quality is good, but only last for 4hours
you can check the other model, but reason I pick that one is because it's using wireless 2.4ghz instead bluetooth.
https://linustechtips.com/topic/319904-best-wireless-headphones/#findComment-4370326
