Best CPU Cooler?
Go to solution Solved by dadasmithywinkle,
Should I save up a bit longer for a refurbished H100i? I heard the H100i is loud as hell though...
I wouldnt. If you're gonna save up, get an H105. Otherwise, get the H80i.
I am looking for a CPU cooler that looks good from a window (so looks good too down) with good temps for 4.4ghz and is under £60 (I can go higher but I would prefer not to)
I always wanted an AIO but at this price range they kinda suck compared to air coolers.
I really want a slick looking, quiet build but there is such a massive range of coolers..
Thanks
https://linustechtips.com/topic/319832-best-cpu-cooler/
a bequiet cooler, they look nice
00110000 00110001 00110000 00110000 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110001 00110001 00100000 00110000 00110001 00110001 00110001 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110001 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110000 00110001
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4346897
Thanks
Corsair H55/H60/H75?
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4346922
Bequiet! Dark Rock Pro 3 gets my vote
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4346934
I was thinking that..
There is a refurbished H80i on scan for £53.
I've bought 3 of the Refub H80i's for client builds and they all run great. Check out my gallery for a couple photos of them :D
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4346937
Saw you talking about them in a previous post so I have already seen them ;)
Do you know how they run compared to a Hyper 212 EVO? As in volume and temps?
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347028
Project Tomahawk:
CPU: Intel Core i7 4790k
Motherboard: Asus Maximus VII Hero
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
PSU: Seasonic M12II EVO 620W
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347030
Better than an Evo, but not as good as a 240mm rad. Probably close to the perf of a mid-range Noctua cooler.
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347040
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347102
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347114
What about a H110? Its only £71 and £4 shipping :)
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347135
It's nice but outdated. I mean, it's better than the H80i for sure, but the fans are lower quality. If you can get one for cheap, though, like the 75 you mentioned, I'd get it.
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347149
My i5 4690K runs really nicely (1.315V) under my Hyper 412S which cost me £28. For Intel CPUs there's no real reason to spend much more than that.
From a looks perspective it's nice too.
35-big-coolermaster-hyper-412s-hyper-212
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347157
So what high end water cooler would you suggest?
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347173
The H80i is a steal as a refurb unit and the H110 that you suggested also sounds like a damn good price. Either would be great. I, personally, use and would advise for the H105. It has a thick rad and can beat the H110 in temps.
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347188
Phanteks PH-TC14PE
Computer Spec: CPU: i5 4690K @ 4.85GHz Delided    Motherboard: ASUS Maximus VII Hero    RAM: Corsair Vengence 2*4GB    GPU: Gigabyte G1 Gaming GTX 970    PSU: Corsair RM650    Boot Drive: Crucial MX100 256GB SSD    Storage: 1TB WD Blue HDD   Case: NZXT H440 Red and Black
Cooling: EK PWM D5 Pump & EK 140ML RES Combo unit , EK Supremacy Evo CPU Block , 360mm Alphacool Radiator , 3 Noctua NF-F12 Fans on the radiator , Some fancy fittings
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347232
Unfortunately there is no refurb H105 and the cheapest price is: £86, compared to other prices, it doesn't seem as good.
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347316
So it's:
Nepton 140XL: £53
H80i: £58
H100i: £71
H110: £75
Which do you think?
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347614
So it's:
Nepton 140XL: £53
H80i: £58
H100i: £71
H110: £75
Which do you think?
The H110i will have the best performance and the H80i is one of the best deals. If I were buying for my next build, I'd get the H80i, because I have experience with them and they work well. I've heard of issues with the H100i and the H110 was just replaced by the newer H110i GT.
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347652
Okay, H80i it is :)
P.S How much more performance will a H100i have over a H80i? And what about volume?
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347681
Okay, H80i it is :)
It will have a bit more performance, as it is a 240mm rad. If you're looking at the H100i for 71, just get the H110 for 74 :)
https://linustechtips.com/topic/319832-best-cpu-cooler/#findComment-4347709
