Noctua Nf-a14 pwm alternative
Solved by WoodenMarker,
That's awesome. Might look into those more. I am looking for a white/black build but if I can't find a fan that is as good as the Nf-14 i might just get one. Thanks
Silent Wings 2's are similar to NF-A14's in terms airflow/noise but has a bit worse static pressure.
And also you can get the PPC version which doesn't come with any accessories but is black, they are louder than the normal ones but with PWM you can bring their RPM wayy lower than noctua says you can, my NF-S12a's can go as low as 120-150RPM!! That is amazing!
iPPC Noctuas aren't really worth getting if the better build quality isn't needed.
