On the GeForce website the compute power of 980 and 960 is given as same - 5.2
980 is wayyyyyyy better but why is it so that the compute performance is the same?
What is the unit of this magical number - FLOPS?
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
I call bullsweet. The 980 is leap years beyond the 960, no way their compute performance is the same. Oh no guys, it's another piece of false advertisement QUICK SOUND THE ALARMS IT'S TIME FOR FLOPGATE!!11!!1!!11
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
I'm confused too!
They just stated 5.2 as compute power!
Can you like the site. I can't find it anywhere
osu! profile
Wtf NVIDIA!!!??
And Titan Z has the same as Titan which is lower than 960. This makes 0 sense.
osu! profile
"The compute capability of a device is represented by a version number, also sometimes called its "SM version". This version number identifies the features supported by the GPU hardware and is used by applications at runtime to determine which hardware features and/or instructions are available on the present GPU.
The compute capability version comprises a major and a minor version number (x.y):
Devices with the same major revision number are of the same core architecture. The major revision number is 5 for devices based on the Maxwell architecture, 3 for devices based on the Kepler architecture, 2 for devices based on the Fermi architecture, and 1 for devices based on the Tesla architecture."
Read more at: http://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#ixzz3SrzRN3FO
Follow us: @GPUComputing on Twitter | NVIDIA on Facebook
Desktop: The Bluez | CPU: i5-3570k @ 4.5 ghz 1.296V | CPU Cooler: Hyper 212 Evo | Motherboard: P8Z77 M-Pro | Memory: 16 GB 1600Mhz Kingston HyperX
GPU: Asus GTX 780ti DirectCu II | HDD: Some Random Hitachi 1TB, WD Blue 1TB, 850 EVO 500GB | PSU: Rosewill Hive 750W | Case: Enermax Ostrog GT (Blue Ver.)
Laptop: Razer Blade 14 2013 256GB
What is the second number?
NVIDIA needs to be clear on their site where they mention these things
Well to take Nvidia's side, they state "compute compatibility" not compute performance. Also the average use wouldn't need to care about such details... It only took me a few minutes to find that snippet in the above post.
Not too sure. Most likely it specifies more specifically what features it has.
I am a beginner in 3D work so I got confused but they should have mentioned it there and then!
Can you tell me what the second number means?
So it also doesn't denote the power?
Then what does?
Here is the chart specifying what the numbers mean.
http://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#compute-capabilities
A better representation of compute power would be the flops performance of each card.
Edit:
For example almost all (if not all)the other cards other than the titans have a limited double precision performance. Thats why they market the Titan for more workstation work.
Edit:
Okay thanks!
Okay thanks!
No problem :)
