Memory Speed
Go to solution Solved by Hieb,
Memory speed makes a small difference outside of file compression and servers.
In gaming it can make a difference when the game is CPU-bound. These days I'd recommend getting 1866-2133MHz if you have a board that supports it, since these usually only cost $5-10 more than a 1600MHz kit.
The results are inconsistent, but it seems like Haswell enjoys having 1866MHz memory.
So will I even notice a difference in my computers performance if I were to get ddr3 1600 vs something like ddr3 3000 or something else?
CPUi7 4790k (4.0 Ghz)| MotherboardMSI Z97 Gaming-5 ATX LGA1150| RAM: 16 Gb Corsair Vengeance Pro(DDR3-1600, Red 4x4Gb)GPUEVGA GTX 980 4GB Superclocked ACX 2.0| CaseFractal Design Define R5 (Black with Window)| StorageWestern Digital Caviar Blue 1TB and Samsung 850 EVO 250 GB SSD| PSUCorsair HX750i 80+ Platinum| Display(s) Asus VG248QE 144Hz 24.0" CoolingCorsair H100i GTX| Keyboard: Corsair K95 RGB| MouseRazer Deathadder Chroma|
https://linustechtips.com/topic/317874-memory-speed/
The difference is negligible. You wont notice it.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/317874-memory-speed/#findComment-4320734
3000? Uhh...
Either way, in gaming there's a small but not very noticeable difference.
So usually it's not worth the money
https://linustechtips.com/topic/317874-memory-speed/#findComment-4320739
Intel i5-4690K @ 3.8GHz || Gigabyte Z97X-SLI || 8GB G.Skill Ripjaws X 1600MHz || Asus GTX 760 2GB @ 1150 / 6400 || 128GB A-Data SX900 + 1TB Toshiba 7200RPM || Corsair RM650 || Fractal 3500W
https://linustechtips.com/topic/317874-memory-speed/#findComment-4320812
Ok cool, well thanks everyone
https://linustechtips.com/topic/317874-memory-speed/#findComment-4320888
