liquid cooling GPU's and CPU + overclocking = more performance?
It's ur money, your call. Ignore those tell you what to do... giving no evidence.
Watercooling will not deliver price/performance ratio. You will not notice any difference if you plan on gaming. The FPS boost from stock to high overclocking GPUs will result less than 15fps... And this is assuming your overclocking is stable.
For the CPU part, on gaming... forget abt it. No game requires high-end cpu to run smooth or better fps. Even highly cpu based games such as minecraft... don't utilize all 4 cores. X99 with 6-8cores... pointless.
At this moment, AMD does not offer any performance on their GPU/CPU. What they have is price. So speaking of high performance you should intel+nVidia. Or maybe wait for AMD300series.
If you opt to go Intel+nVidia. From my experience is that gtx980 SLI at TDP 165w*2. Even you overclock it, watercooling is unnecessary. You can take the heat to other location or direction depending on the radiator. And also let it run quieter. But speaking of performance, not so much of improvement if you want it stable.
If you take something like R9-295X2. tdp at 500. Watercooling makes much more sense, but less performance+spending more. I really don't think there's a reason to choose this config. Besides, it already come with AIO.
CPU overclocking is much more noticeable from my experience. Especially when you unzip files, or even in basic modeling/rendering. But I really doubt there's any reason to spend all that $$ "just" for the performance.
Go for a silent build with a custom loop and nice looking tubing etc... I think that will suit you best
