That's like saying people usually die in africa, but someone died in USA. (It can happen to any mouse)
It's a common issue with razer mouses (LOGITECH MASTER RACE)
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/316864-razer-naga-double-click/#findComment-4306892
this issue can occur on any mouse out there.
not being funny but the same issue you have has occurred to 3 of my friends who have Razer mouse  :lol:  Logitech ftw.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/316864-razer-naga-double-click/#findComment-4306988
I use a Razer Mamba 2012, and without any more info I'm going to diagnose your problem to lie with the Synapse 2.0 software.
Their hardware is typically on point, but this clumbsy software ruins everything it interacts with. I'm just glad my Razer mousepad doesn't require being linked to Razer Synapse 2.0 in order to function the way my mouse does.
Try re-installing (first super-uninstalling) the Synapse 2.0 software. Maybe you should try a second computer first to see if the symptoms persist. If both fail, dis-assemble and re-assemble the mouse (if it's out of warranty) then I bet it will magically work again.
https://linustechtips.com/topic/316864-razer-naga-double-click/#findComment-4307472
I don't see how reinstalling would fix this...
Crimson Panda
http://pcpartpicker.com/list/g6T8QV
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/316864-razer-naga-double-click/#findComment-4317419
I've owned 4 Razer mice by this point and I love them. That being said, they don't really last what I consider fairly continuous use for too long. Take for example: I have only bought 2 Deathadders yet I have owned 4. The second two are warranty replacements from my computer shop due to either scroll wheel or mouse button failure after fairly predictable durations.
Ole #4 has been kicking for a couple years and just now is starting to double click. I've come to expect it but I haven't found a mouse that works better for me yet.
You could try getting it RMA'd if its still under warranty, as its probably hardware rather than software.
littleRed
CPU Intel i7 4790k Motherboard ASUS ROG Maximus VII Hero RAM 32GB G Skill RipjawsX GPU EVGA Titan X Cooling Corsair H105 Case Corsair 760t Black PSU EVGA 1000P2
Storage Boot Samsung Evo 850 256GB Programs Samsung Evo 840 1TB Data WD Black 2TB Display BenQ XL2420G Keyboard Corsair K70 Mouse Razer Death Adder OS Windows 10
https://linustechtips.com/topic/316864-razer-naga-double-click/#findComment-4317487
It's sort of like josseling the vending machine that has your candy-bar stuck. It shouldn't really do anything, but it yields results. I've had success with doing the following: Uninstalling, restarting and then reinstalling (while mouse is unplugged.) This may "clear the air" a bit in the system; the problem could have stemmed from a Windows file which had become corrupt.
https://linustechtips.com/topic/316864-razer-naga-double-click/#findComment-4324525
I am using a mac. I tried reinstalling and nothing really happened.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/316864-razer-naga-double-click/#findComment-4328950
