What exactly i need ?
Go to solution Solved by Xsilent(X),
Actually its not about coning . i heard if you can build a better cluster for mining that will be best for folding . i'll donate this whole 10 to 20 computer cluster for medical research but i'll do mining for a month to make my self sure that what i'm donating have worth .
you need asics to mine these days. gpu mining will not get you anywhere. even for 6K  for 20000MH/s you will make like 0.5 ltc p/d wat is like 0.63 cents a day. still asics are expensive for wat you will get. never mind the diff vary! till you have gotten you're asics that asic miner will become obsolete.
if you like to contribute just buy 3 970 or 2 R9 295X2 and fold away :)
Hi mates
its about bit coin mining.
i know if i jump in many stake holders will be even here.lol
but
i want to know if i build a 20 computer's cluster for mining
how much powerful systems i need for a better miner
and what kinda software i need .
Thanks in advance
CPU: i7 4790K | Ram:Corsair Vengeance 8GB | GPU: Asus R9 270 | Cooling :Corsair H100i | Storage : Intel SSD, Seagate HDDs | PSU : Corsair VS 550 | Case: CM HAF Advanced.
https://linustechtips.com/topic/316091-what-exactly-i-need/
why are you trying to waste money?
you would make more money by buying lottery tickets that never win.
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4295875
hahahahahahahahh. just to give it a try . i have plan to gather 10 coins and then i'll donate whole cluster for folding .
actually i came to know about folding few days back and i think it will be the best way to put your money as donation coz it will help masses . so its actually a powerful enough fold but i'll wanna try mining on it too.
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4295903
so how many thousands of dollars are you planning to spend *aka lose* on this?
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4295920
50K-70K
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4296319
290x has a hash rate of 1 MH/s which is terrible, according to some random bitcoin forum.
With a thousand 290x's it'll take you 92827.72 Day(s) to get 1 BTC... Just don't even bother...
ok 290X to trash in this regard. GTX 980s?
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4296323
Those are even worse, 290x is one of the best card for mining crytocurrency.
Would you plz make a list of a miner under 6K? USD
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4296408
don't waist any resources to coin mining
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4296429
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4296484
You shouldn't really do mining.
I don't want to reccomend anything as I don't feel like anyone should mine.
If you want to know more you should do some research yourself, 6000 dollars is a huge investment, and my reccomendation wouldn't be based on personal experience.
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4296492
Totally professional and truthful person's reply . hat's off man .
this cluster will be used for medical research buddy. plz my reply above your post. then if you can plz advise.
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4296518
If you're building a folding farm I'd reccomend getting 3 970's and calling it a day.
Though if you really want to spend more you can always get multiple systems with 970's.
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4296544
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4296573
you need asics to mine these days. gpu folding will not get you anywhere. even for 6K  for 20000MH/s you will make like 0.5 ltc p/d wat is like 0.63 cents a day. still asics are expensive for wat you will get. never mind the diff vary! till you have gotten you're asics that asic miner will become obsolete.
hmmmmm.thought full.
i'll give it a thought
https://linustechtips.com/topic/316091-what-exactly-i-need/#findComment-4296682
