GeForce Drivers Issue
I have a rather big issue. After a recent driver update i have been having issues here is how it goes:
1. Installed new drivers
2. Restarted computer
3. GPU fans go to 100%
4. WIndows wont go to full resolution
5. Geforce Experience wont do anything than let me install the drivers i just installed
6. install the drivers
7. Restart
8. Problem still not fixed
9. Uninstall everything having to do with nvidia
10. Restart
11. Reinstall everything having to do with nvidia
12. Restart
13. It works!!!
Now obviously i cant do this every time i turn the computer off and on. Any solutions?
https://linustechtips.com/topic/315996-geforce-drivers-issue/
Check that you have all windows updates installed after you update your drivers.
If you still have issues try reverting to the previous driver version, and select clean install during the installation process
https://linustechtips.com/topic/315996-geforce-drivers-issue/#findComment-4294567
