I really like this case but if I owned one I would do something about the front panel because I think it would look better without any break for an odd even if it is slimline it still stops it from being a smooth panel. It's just a small thing but maybe another window?? cause the stock paint is really nice so filler and then paint might not be the best option, I don't know maybe it's just me
Actually you are right, but the way it stands on my desk you do not see ti much, because my monitor stands direktly beside it.
https://linustechtips.com/topic/31584-razers-edge/page/2/#findComment-420535
I took a Prolimatech MK-26.
I dont know whether you understood what I asked I said why not what.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/31584-razers-edge/page/2/#findComment-420731
Oh soory, Ichose tjis one because the one of the Palit Jetstream was with blue lighting. Rhis one is black and can take every fan I want. Hope now your question is answered.
https://linustechtips.com/topic/31584-razers-edge/page/2/#findComment-421372
Really nice build, love the case.
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
https://linustechtips.com/topic/31584-razers-edge/page/2/#findComment-422966
dat sleeving is amazing must have taken a lot of time and effort to get that finished product, excellent job man, excellent job!
Yes, it ook quiet a while, but it was worth it. The sleevingg is so good because it is MDPC, the best sleeving you can get, in my opinion.
https://linustechtips.com/topic/31584-razers-edge/page/2/#findComment-423074
Really nice build man. Love how neat your window cut out is.
I was wondering what did you use to cut the side panel, cause the aluminium is pretty thick. Also how thick is the acrylic that you used and how did you attach it?
Have you considered using a black marker to color in the edge of the cut? I just think it would look a tiny bit better.
https://linustechtips.com/topic/31584-razers-edge/page/2/#findComment-425368
Thank you man. As mentioned in another Post, I have a neighbour, who has got a watercutter at work. He did it for me. Th eacrylic is 3mm thick and is attached with thick double sided tape.
Maybe I will take a marker to paint the cut, did not think of it. The problem would be the tape is very strong and and the window won´t come off, so I might paint the window, which be bad.
https://linustechtips.com/topic/31584-razers-edge/page/2/#findComment-425428
  • 2 weeks later...
@Streetstyler
That is one BADASS case! I would definitely try something like that, I would prefer an H80 or H60 tho.
Also, u should do a video on how u got that window on :P
Thanks, I like this case as well. I thoght on an h80i, but I thought this cooler looks nicer. The window is watercut, so nothing special to make a video about.
https://linustechtips.com/topic/31584-razers-edge/page/2/#findComment-504898
