Starting tips for photography
Solved by LancerBG,
keep saving your money, double your budget then start to look. Spending on a good camera is worth it, will last you years and years with zero need to upgrade. you can get an ok entry level camera at your current price point but those are the ones you are going to want to replace in a couple years. you will outgrow them pretty fast. another train of thought is that you can buy a camera now in your price range to see if you are serious or not about photography that way you dont need to spend and arm and an leg. Thing is if you buy a really good camera you can sell it at any time and still get a good return on what you spent. entry level not so much.
