1866Mhz RAM showing 932Mhz !
Solved by Oshino Shinobu,
DDR = Double Data Rate. So it's actually 932Mhz x2. It's running at the correct speed.
EDIT: @Aniallation It's the Double Data Rate that makes it appear as 932, not Dual Channel. Even RAM running in single channel will show as 932 and effectively be 1866.
Featured Topics
4
12
5
1
6
10
kodokuj ·
Posted in Graphics Cards2 -
Repoball ·
Posted in Troubleshooting3 -
OybeX3D ·
Posted in Operating Systems0
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
