A shorter air cooler?
Solved by Senzelian,
This should work fine.So I need a cooler that is low profile for LGA 1150!!
I need it low but have enough cooling capacity to possibly put a slight overclock on this (http://www.scan.co.uk/products/intel-core-i5-4690k-s1150-haswell-4-core-35ghz-39ghz-turbo-5-gt-s-dmi-12ghz-gpu-34x-ratio-84w-retail)
Thanks in advance
Thing
https://pcpartpicker.com/part/be-quiet-cpu-cooler-bk012
Like below 7cm!!
Thing
Wuut? o_O
