Help with wacom tablet.
Go to solution Solved by minibois,
So I got a wacom intuos and when I pick up the pen off the active area and move to then place it down again the cursor moves to the new location. How can I make it so it doesn't do that? Like if I picked up my mouse and moved it, it wouldn't move to the new location when I placed it down. The wacom bamboo tablets at my school don't do this.. :c
Go into the Wacom software (if installed from the website) go to tablet-display relation (something like that, I have it in Dutch) and press mouse instead of tablet.
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/313507-help-with-wacom-tablet/
dont you want it to do that?
think of the tablet as a touchscreen.
https://linustechtips.com/topic/313507-help-with-wacom-tablet/#findComment-4261618
https://linustechtips.com/topic/313507-help-with-wacom-tablet/#findComment-4261631
no, ill post a gif of what i mean, it's hard to explain, I only want it to move when im actually using the pen.
post-5552-0-38607100-1424369285_thumb.gi
found it, thats what i wanted :) thanks
https://linustechtips.com/topic/313507-help-with-wacom-tablet/#findComment-4261661
had this issue when i borrowed my friend's tablet for lightroom and it's annoying as hell.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/313507-help-with-wacom-tablet/#findComment-4261672
Not to sure what you mean :( screenshot please?
Ik what you mean, I have a walcom tablet.
Think of it as a touch screen. If you lift your finger and put it in top corner, cursor jumps their.
https://linustechtips.com/topic/313507-help-with-wacom-tablet/#findComment-4261686
but i don't want it to do that :P
https://linustechtips.com/topic/313507-help-with-wacom-tablet/#findComment-4261692
Oh well I like it doing that.
So I'm not much help here.
I'm out
https://linustechtips.com/topic/313507-help-with-wacom-tablet/#findComment-4261702
