NH-D15
You can bet that thermals will not be the limit in OC'ing with this thing
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/312650-best-air-cooler/#findComment-4249421
Have you already OCed the CPU to its Thermal limit ?
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/312650-best-air-cooler/#findComment-4249439
http://www.amazon.co.uk/Akasa-AK-CC4010HP01-Venom-Medusa-Cooler/dp/B00BQ8A6HW
2 towers, eight heat pipes, amazing performance fans fitted as stock.
Edit: Also, not for silent computing and completely pointless unless you're going to overclock.
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/312650-best-air-cooler/#findComment-4250391
Noctua NH-D15, the thing is a BEAST.
4 heat pipes. The Medusa has 8. http://www.amazon.co.uk/Akasa-AK-CC4010HP01-Venom-Medusa-Cooler/dp/B00BQ8A6HW
;0)
https://linustechtips.com/topic/312650-best-air-cooler/#findComment-4251770
Im searching for the best air cooler possible? And to which kind of Ghz can you oc with a air cooler (i5 4690k) would I be able to oc too his maximum ?
You're going to be limited by the architecture of the chip and the crappy TIM in between the die and the IHS than your CPU cooler choice.
Most dual tower heat sinks are not worth it (e.g. NH-D15) because they're expensive, they have compatibility issues with cases, RAM, and PCIe slots, and they put a lot of load on your motherboard.
If it's available in your market, I suggest the Scythe Kotetsu. Small, simple, budget friendly, and surprisingly effective. Though if you hit a sale on one of the flagship dual tower coolers, and you have the case/RAM/mobo for it, they won't disappoint. And @GuruMeditationError there are many more important things to a heatsink's performance than heat pipe count.
Titan: Intel Core i7-5820K | ASUS X99-A | Crucial Ballistix Sport 4x4GB DDR4-2400 | ASUS Strix GeForce GTX 970 | OCZ Arc 100 2x256GB in RAID 0 | Seagate Barracuda 2x2TB in RAID 1
EVGA SuperNOVA 750 G2 | Fractal Design Define R5 Titanium Window | Phanteks PH-TC14PE | ASUS BW-12B1ST
https://linustechtips.com/topic/312650-best-air-cooler/#findComment-4252101
Well in essence that's the universal answer to every question ever. ;0)
https://linustechtips.com/topic/312650-best-air-cooler/#findComment-4252320
Then I shall provide a less universal answer. xD
Influencers on typical heat sink performance, in order of impact:
  1. Quality of contact between heat sink and CPU.
  2. Quality of contact between heat sink base and heat pipes.
  3. Quality of contact between heat pipes and fin array.
  4. Other things.
If you can't get the heat from the CPU to the cooler/heat pipes, it doesn't matter how many heat pipes you have. And if you can't get the heat from the pipes to the fins, it doesn't matter how many fins or heat pipes you have.
https://linustechtips.com/topic/312650-best-air-cooler/#findComment-4252386
CoolerMaster Hyper 212 EVO for stock and mild overclocks.
Noctua NH-D15 for medium to high overclocks
Closed loop water cooling if you're insane.
CPU: Intel i5 2500k @4.2Ghz Cooling: Be Quiet! Silent Loop 120mm MB: MSI Z77A-G45 GPU: Sapphire R9 280X Vapor-X OC RAM: 8Gb G.Skill Ripjaw @ 1600mhz
Storage 1:Samsung 840 120gb SSD Storage 2: Seagate Barracuda 2Tb HDD PSU:Corsair CX 750W  Case: Corsair Carbide 400R.
https://linustechtips.com/topic/312650-best-air-cooler/#findComment-4258515
