Headset is making me crazy
Ok so i bought a new headset(bluetooth Coolnice V8) i instaled all the drivers but one of the doesnt wanna work, im assuming for the microphone because i can hear my friend but he cant hear, my Coolnice(mono audio)  cant start. Thank you for any help ( if u need more info il share it )
https://linustechtips.com/topic/312149-headset-is-making-me-crazy/
1. Go into windows recording settings http://puu.sh/g10yZ/e23951a859.png
2. Select your mic http://puu.sh/g10AC/f0b5a59bd1.png
3. Press select default.
You also might have to mess with your settings in the chat program you are using to select your mic.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Make sure the microphone plugs are plugged into the proper jacks or whatever on the motherboard or sound card.
Nice advice....
Done but doesnt wrok
Windows Bluetooth compatibility is very spotty. IMO, it would be best to cut your losses, return the headset, and try something from a different brand.
